Old 02-13-2016, 12:25 PM   #1
FRSure
Drives: Toyota
New Wheel, Alignment?
Quick question.
I am changing wheels from Stock wheels to XXR 527.
The specs are 17x8.25, 35 offset.
Because it is the same wheel size as stock, but just wider and a bit less offset, would I need an alignment?
FRSure is offline   Reply With Quote
Old 02-13-2016, 01:29 PM   #2
EzyBrzy
Drives: 2015 WRB BRZ
No.
EzyBrzy is offline   Reply With Quote
Old 02-13-2016, 01:42 PM   #3
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Curious about this myself..
Alignment is only needed when you change your suspension setup or modify the settings right? So if I changed the height of coilovers, I'd need to get em aligned?
PandaSPUR is offline   Reply With Quote
Old 02-13-2016, 02:12 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
OP, no alignment is needed. However, are you getting new tires? Or how long have you had the car? It might be a good idea to get an alignment, to make sure everything is all good.
But new wheels/tires will not necessitate an alignment.
@PandaSPUR Correct-need an alignment if you adjust height. Even removing/reinstalling the suspension(without adjusting settings) its still a good idea for an alignment though, since its very possible things won't got back exactly the way it was.
Old 02-14-2016, 12:34 AM   #5
FRSure
Drives: Toyota
Same tires, just on new wheels.
I just had an alignment done 2 months ago.
Thanks shutter!
Tyre/Wheel rotation and wheel alignment for the 86? FT_86_SM_GP AFRICA 17 11-05-2015 04:01 PM
Wheel Alignment scottxnizzle Southern California 14 03-13-2015 10:15 AM
wheel alignment needed? j2digit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-10-2013 05:32 PM
Wheel works cant do alignment? maxx1957 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-16-2013 09:50 AM
RTR Wheel Alignment simpleisbest Tracking / Autocross / HPDE / Drifting 61 11-07-2012 07:48 PM
