Old 02-07-2016, 11:19 AM   #1
djdrugga24
Drives: Asphalt 2013 Scion FR-S
What should I do to my car in preparing for a supercharger?
I am planning on purchasing and installing a supercharger next year. Before that happens, I would like to prepare my car before adding all that horsepower.
I currently only have a Takeda Cold Air Intake installed in my car.
I was planning on installing the following this year:
- INVIDIA N1 Exhuast
- STOPTECH FRONT AND REAR UPGRADE brake package (still not too sure about this brand)
- Eibach Pro-Kit Springs
- Eibach Anti-Roll Kit
I know that my Cold Air Intake will have to be removed for the intake that comes with a supercharger.
Any comments on what I am planning to buy or what I should buy.
I would really appreciate it.
djdrugga24 is offline   Reply With Quote
Old 02-07-2016, 11:45 AM   #2
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Axles
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
The Following User Says Thank You to texasbound972 For This Useful Post:
go_a_way1 (02-07-2016)
Old 02-07-2016, 11:48 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Well your going to want an oil cooler, tranny cooler if AT, and new tires at the very bare minimum. If you want to maximize the extra HP your going to want to do a little suspension work such as various bushings to help keep wheel hop under control. No point in lowering springs for a supercharger those are more for looks then performance but nothing wrong with installing them. Hold off on swaybars until your done all the suspension work your going to as those are a fine tuning part that should be done last to give you the feel you want as a driver. If your planning on more then just DD you should upgrade your radiator as well. As for exhaust your cat back does nothing but make noise if you want to make power replace the header and midpipe to get rid of both catalytic converters. As for bakes its not a bad idea to upgrade those if your driving aggressive but honestly just some better pads and fluid is all you need to do to start untik your driving improves on the track and demands better brakes. For steet driving you wont need brakes. You may also want to get some gauges to keep and eye on your engine. I would go with oil temp, oil pressure, and coolant temp, and boost in that order provided you want to get all 4. Thats about all I can think of right now. Enjoy your new supercharger next year
Edit: oh and alxes like said above if you launch it
Leonardo (02-07-2016)
Old 02-07-2016, 12:07 PM   #4
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Headerback, and some Michelin PSS(;
Alltezza is offline   Reply With Quote
Old 02-07-2016, 12:46 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Nothing, buy the SC first and go from there.
Old 02-07-2016, 12:54 PM   #6
twag4
Drives: frs
I am supercharged, my stock axles are fine.
twag4 is offline   Reply With Quote
Old 02-07-2016, 12:59 PM   #7
LS1M
Drives: 2015 BRZ
Absolutely agree...
Make sure an oil cooler comes with the s/c kit
Might want an oil pressure gauge
Everything else you can view via ODB2 (torque app)
When you do the install, might want to switch from 0w20 to something thicker
Other than that, you can upgrade parts as you need them
(clutch, tires, etc.)
depending on what you do with the car...
-Mark
LS1M is offline   Reply With Quote
The Following 2 Users Say Thank You to LS1M For This Useful Post:
GsxrMe (02-07-2016), paiceyfan (02-08-2016)
Old 02-07-2016, 11:25 PM   #8
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by LS1M View Post
Absolutely agree...
-Mark
Bingo! Ya switch to 10w30. And start with low base map tune and go from there.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-08-2016, 12:28 AM   #9
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Get the supercharger + ecutek kit first and then in terms of upgrades to compliment the added power, at the very minimum, oil cooler, top tier tune/tuner, better brake pads and sticky summer tires. I just recently installed the Jackson Racing supercharger as well.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 02-08-2016, 01:37 AM   #10
FRS Justin
Drives: 2013 Asphalt FRS
Depends on how you are going to drive you car. Drag, track, street only? I assume from your mod list just a mild daily driver.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 02-08-2016, 02:40 AM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
fml.
Old 02-08-2016, 03:06 AM   #12
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Absolutely agree...
-Mark
I agree with this as well, but if you'll never track your car then you don't really need an oil cooler or oil pressure gauge. If you live somewhere that's cold, I'd stick with 0w-20 in the winter, otherwise get something at least 5w30. Everything else you upgrade power wise won't give you very much hp per $ spent compared to a supercharger (or turbo). If you intend on going with something that puts you over 300whp/260wtq, then you'll need a clutch, injectors, fuel pump. If you go over 330hp/280wtq or so, then you should think about getting forged internals/built engine. Getting a flex fuel kit and running e85 will give you more power and a cooler running engine, but if you're like most of us, it's either a hassle to get or not available in your area. Plus e85 will get you 20% worse fuel economy, but if it's 20% cheaper compared to 91oct+, then it balances out.
stockysnail is offline   Reply With Quote
Old 02-08-2016, 08:08 AM   #13
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Choose the supercharger, tune, fuel and power target first then you will be able to identify what modifications are actually required. Track use has to be figured into the equation as well.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 02-08-2016, 08:20 AM   #14
Andew727
Drives: Scion FR-S
Depending on supercharger
-strengthen valve springs
-Oil Cooler (thermostatic) depending on location
-Proper oil catch/separator can
-new clutch
-stiffen up the drivetrain
-E85 with boost is always safer
Andew727 is offline   Reply With Quote
Preparing for winter! Elliryx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 09-03-2015 09:14 AM
Preparing for a road trip nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-07-2015 12:42 PM
Preparing for my First Track Day/autocross in October, I want to spend some money jflogerzi Tracking / Autocross / HPDE / Drifting 35 10-07-2013 06:15 PM
EcuTek preparing to release PRO ECU software for BRZ Visconti Engine, Exhaust, Transmission 335 08-13-2012 11:34 PM
