Drives: Asphalt 2013 Scion FR-S
What should I do to my car in preparing for a supercharger?
I am planning on purchasing and installing a supercharger next year. Before that happens, I would like to prepare my car before adding all that horsepower.
I currently only have a Takeda Cold Air Intake installed in my car. I was planning on installing the following this year: - INVIDIA N1 Exhuast - STOPTECH FRONT AND REAR UPGRADE brake package (still not too sure about this brand) - Eibach Pro-Kit Springs - Eibach Anti-Roll Kit I know that my Cold Air Intake will have to be removed for the intake that comes with a supercharger. Any comments on what I am planning to buy or what I should buy. I would really appreciate it. |
#2 |
USMC
Drives: 2013 FR-S 6-MT Raven
Axles
Sent from my SAMSUNG-SM-N920A using Tapatalk |
| The Following User Says Thank You to texasbound972 For This Useful Post: | go_a_way1 (02-07-2016) |
#3 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
![]() Edit: oh and alxes like said above if you launch it |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Leonardo (02-07-2016) |
#4 |
Drives: WRB Limited BRZ
Headerback, and some Michelin PSS(;
#5 |
Drives: RX-7 / BRZ
Nothing, buy the SC first and go from there.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#6 |
Drives: frs
I am supercharged, my stock axles are fine.
#7 |
Drives: 2015 BRZ
Absolutely agree...
Make sure an oil cooler comes with the s/c kit Might want an oil pressure gauge Everything else you can view via ODB2 (torque app) When you do the install, might want to switch from 0w20 to something thicker Other than that, you can upgrade parts as you need them (clutch, tires, etc.) depending on what you do with the car... -Mark |
#8 | |
Drives: Late 2014 Subaru BRZ
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#9 | |
Drives: '13 UM86
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport |
#10 |
Drives: 2013 Asphalt FRS
Depends on how you are going to drive you car. Drag, track, street only? I assume from your mod list just a mild daily driver.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#11 |
Junior
Drives: a car
fml.
#12 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#13 |
Drives: 2013 FRS / 2013 427 Vert
Choose the supercharger, tune, fuel and power target first then you will be able to identify what modifications are actually required. Track use has to be figured into the equation as well.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#14 | |
Drives: Scion FR-S
-strengthen valve springs -Oil Cooler (thermostatic) depending on location -Proper oil catch/separator can -new clutch -stiffen up the drivetrain -E85 with boost is always safer |
| Preparing for winter! | Elliryx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 09-03-2015 09:14 AM |
| Preparing for a road trip | nickw14 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 05-07-2015 12:42 PM |
| Preparing for my First Track Day/autocross in October, I want to spend some money | jflogerzi | Tracking / Autocross / HPDE / Drifting | 35 | 10-07-2013 06:15 PM |
| EcuTek preparing to release PRO ECU software for BRZ | Visconti | Engine, Exhaust, Transmission | 335 | 08-13-2012 11:34 PM |
