Old 02-04-2016, 01:04 AM   #1
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Manual vs. Electronic controller for air ride suspension. Should I spend the money?
So I'm going to be picking up a bag system soon and I've come to notice if I want an electronic controller it is significantly more expensive than if I were to just get a manual controller. Is there some huge benefit to electronic over just a manual system? Why should I spend hundreds more on it?
wise345 is offline   Reply With Quote
Old 02-06-2016, 08:44 PM   #2
Bluehwy
Bluehwy's Avatar
Drives: 2013 FRS
I have just ordered the Airlift V2 system and prior to that I was asking a lot of the same question that you are. So i'll share my story and hopefully it helps with your decision.
Manual System:
Is basically what it sounds like, you have 4 paddle switches and each switch controls an air bag. So if you air out your car when you park it, upon re-entering you have to individually air up each air bag.
Digital System:
With the digital system you can program your car to raise to a certain pressure when you start your car. It will also monitor pressure in your bags so if you have a slow leak it can maintain pressure in your system long enough to get somewhere safe.
What sold me on the Digital vs Manual was installation. I will be doing my own install, so I wanted a kit that was fairly straight forward.
If you look at the manual kit you have a bar with 4 paddle switches and 2 pressure gauges that need to be mounted fairly close together. Also it needs to be a fairly spacious area because if you look at the plumbing diagram for the switches and gauges its a mess of hoses that you need to run behind there.
With the Digital kit its just one wire and one control I can tuck neatly away in the front, the rest of the wiring and plumbing will be in the trunk.
Hope this helps!
Bluehwy is offline   Reply With Quote
Electronic Boost Controller BRZtoni Forced Induction 9 01-21-2018 01:38 PM
AVO DBW electronic throttle controller Setup AVOturboworld DIY (Do-It-Yourself) Guides 22 03-31-2016 06:11 PM
Electronic Boost Controller Issues 1BadFA20 Forced Induction 1 06-09-2014 01:21 AM
What should I spend my money on sf86 Scion FR-S / Toyota 86 GT86 General Forum 49 11-28-2012 04:34 PM
