Northwest AK, ID, OR, WA
Old 01-30-2016, 05:25 PM   #1
Bat_mobile
Bat_mobile's Avatar
Drives: It's the batmobile
Fender rolling?
Anyone know of someone to roll fenders, preferably around Bellevue? I have my stance coils in the garage waiting to be put on. Also, how low do you think I could go on 18x8.5 +38 offset on 245/40/18 tires?
Check out the Eastside 86 group on Facebook!
Bat_mobile is offline   Reply With Quote
Old 01-30-2016, 05:41 PM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I have stance coils on 18x8.5+45 with 235/40 tires and I didn't have to roll my fenders. My car is pretty low. But I don't recall how low I lowered it.
Chen is offline   Reply With Quote
Old 01-30-2016, 06:49 PM   #3
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I own an Eastwood fender roller. Never done it for an 86 before but you can rent it from me and do it yourself.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 01-30-2016, 07:56 PM   #4
Locust
Custom User Title
Locust's Avatar
That extra 7mm makes a pretty big difference though.
I should also clarify I don't charge for it just need a deposit so I know I'll get it back. Or I can walk you through it I guess if there's a sunny weekend coming up sometime. Fender rolling is so easy no one should ever pay people to do it for them.
LOCUST
Instagram:
LocustAutoX
Sponsors:
The Following User Says Thank You to Locust For This Useful Post:
bcj (01-30-2016)
Old 01-31-2016, 01:26 AM   #5
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
I'm running 18x8.5 +35 and I'm lowered about 1.75 inches no need to roll the fenders unless you are going stance
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 01-31-2016, 01:43 AM   #6
gtslow
Drives: 2015 Halo FR-S
Looking in the wheel directory below it looks like you should fit.
http://www.ft86club.com/forums/showthread.php?t=7535
Ride height is hit or miss and you should plan to be playing with it a bit to get it where you like and what matches the type of driving you plan to do.
This thread is also interesting:
http://www.ft86club.com/forums/showthread.php?t=25177
gtslow is offline   Reply With Quote
Old 01-31-2016, 03:43 PM   #7
tyler_win_photo
tyler_win_photo's Avatar
I don't think you'll need to roll your fenders with that setup. I'm running 18x9.5 +35 with 235/40 lowered about 1.8-2 inches and it rubs on the plastic tab in the rear only under really heavy compression. Even then, the rubbing has mostly disappeared since it's worn itself down.
As for how low you could probably go, you can probably go until your tires hit the inner fender well. Just keep in mind that the spring rate for the stance coilovers is somewhat soft at 6k f/r. And also keep in mind that you'll likely need rear lcas if you're planning on going max low as the camber wear in the rear will get real bad, real quick.
tyler_win_photo is offline   Reply With Quote
Old 02-02-2016, 04:05 AM   #8
Bat_mobile
Bat_mobile's Avatar
What rate should I use? I want a nice ride that is close to stock. I'm not going mad low. Just like 1.5-2 inches
Old 02-02-2016, 06:58 PM   #9
tyler_win_photo
You can only change the spring rate by buying new springs - such as Swift. You'll be fine with 1.5-2 inch drop on your current spring rate.
Old 02-04-2016, 01:31 PM   #10
Bat_mobile
Bat_mobile's Avatar
So since they are coils and not springs, you don't change it?
Old 02-04-2016, 05:38 PM   #11
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
Your spring rate isn't something that you can change, it's the amount of weight it takes for the spring to compress. You can buy different springs and put them on your coils, though.
MalcolmHimself is offline   Reply With Quote
Old 02-04-2016, 05:42 PM   #12
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
you do realize that your coil-overs have springs on them, and you can change these springs to get a different spring rate. however a change in spring rate will require you to change the dampening setting on the struts to find the right ride softness/stiffness.
to your original questions, you shouldn't need to roll your fenders with your current wheels.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 02-07-2016, 04:28 PM   #13
Bat_mobile
Bat_mobile's Avatar
I know they have springs, but I meant springs alone. I just hear a lot of people saying I'm running such and such spring rate. I want to make sure I do this correctly so I don't ruin my car. Do it right or do it twice.
Old 02-08-2016, 02:48 PM   #14
RobertPaulson
Drives: 2017 Golf R
well you've already bought your coils so are you ready to buy it twice?
i'd strongly suggest you do some research so you can get the best setup for your needs. however i know you're more about the stance and look than you are performance so i say slam the shit out of it and just accept that the ride won't be that great.
if you're still looking to learn, here's some good places to start.
start here http://www.ft86club.com/forums/showthread.php?t=9936
search this thread, if you don't find an answer ask. http://www.ft86club.com/forums/showthread.php?t=45554
and lastly look this one over http://www.ft86club.com/forums/showthread.php?t=26661
good luck
DIY fender rolling and pulling? OICU812 DIY (Do-It-Yourself) Guides 12 01-02-2017 09:02 PM
Fender rolling/pulling Bergen23 CANADA 19 03-17-2015 07:55 PM
Cheapest FRS/BRZ fender rolling Service! syndicatemotorsports Exterior Parts - The Rest 10 07-03-2014 03:27 PM
fender rolling and pulling shops in so cal SmsAlSuwaidi Southern California 15 10-08-2013 06:31 PM
fender rolling Andybui82 Northwest 0 03-30-2013 10:44 PM
