| Northwest AK, ID, OR, WA |
Drives: It's the batmobile
Fender rolling?
Anyone know of someone to roll fenders, preferably around Bellevue? I have my stance coils in the garage waiting to be put on. Also, how low do you think I could go on 18x8.5 +38 offset on 245/40/18 tires?
Check out the Eastside 86 group on Facebook! |
#2 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I have stance coils on 18x8.5+45 with 235/40 tires and I didn't have to roll my fenders. My car is pretty low. But I don't recall how low I lowered it.
#3 |
Custom User Title
I own an Eastwood fender roller. Never done it for an 86 before but you can rent it from me and do it yourself.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#4 | |
Custom User Title
I should also clarify I don't charge for it just need a deposit so I know I'll get it back. Or I can walk you through it I guess if there's a sunny weekend coming up sometime. Fender rolling is so easy no one should ever pay people to do it for them.
#5 |
Wasian Ninja
Drives: 2013 Crystal Black Silica BRZ-L
I'm running 18x8.5 +35 and I'm lowered about 1.75 inches no need to roll the fenders unless you are going stance
check out my build thread here
![]() Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold) |
#6 |
Drives: 2015 Halo FR-S
Looking in the wheel directory below it looks like you should fit.
http://www.ft86club.com/forums/showthread.php?t=7535 Ride height is hit or miss and you should plan to be playing with it a bit to get it where you like and what matches the type of driving you plan to do. This thread is also interesting: http://www.ft86club.com/forums/showthread.php?t=25177 |
#7 |
Drives: 2014 Scion FRS (Asphalt)
I don't think you'll need to roll your fenders with that setup. I'm running 18x9.5 +35 with 235/40 lowered about 1.8-2 inches and it rubs on the plastic tab in the rear only under really heavy compression. Even then, the rubbing has mostly disappeared since it's worn itself down.
As for how low you could probably go, you can probably go until your tires hit the inner fender well. Just keep in mind that the spring rate for the stance coilovers is somewhat soft at 6k f/r. And also keep in mind that you'll likely need rear lcas if you're planning on going max low as the camber wear in the rear will get real bad, real quick. |
#8 |
What rate should I use? I want a nice ride that is close to stock. I'm not going mad low. Just like 1.5-2 inches
#9 |
#10 |
So since they are coils and not springs, you don't change it?
#11 |
Drives: 2015 BRZ
Your spring rate isn't something that you can change, it's the amount of weight it takes for the spring to compress. You can buy different springs and put them on your coils, though.
#12 | |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
however a change in spring rate will require you to change the dampening setting on the struts to find the right ride softness/stiffness. to your original questions, you shouldn't need to roll your fenders with your current wheels.
This is your life and it's ending one minute at a time.
#13 | |
#14 | |
Drives: 2017 Golf R
i'd strongly suggest you do some research so you can get the best setup for your needs. however i know you're more about the stance and look than you are performance so i say slam the shit out of it and just accept that the ride won't be that great. if you're still looking to learn, here's some good places to start. start here http://www.ft86club.com/forums/showthread.php?t=9936 search this thread, if you don't find an answer ask. http://www.ft86club.com/forums/showthread.php?t=45554 and lastly look this one over http://www.ft86club.com/forums/showthread.php?t=26661 good luck
| DIY fender rolling and pulling? | OICU812 | DIY (Do-It-Yourself) Guides | 12 | 01-02-2017 09:02 PM |
| Fender rolling/pulling | Bergen23 | CANADA | 19 | 03-17-2015 07:55 PM |
| Cheapest FRS/BRZ fender rolling Service! | syndicatemotorsports | Exterior Parts - The Rest | 10 | 07-03-2014 03:27 PM |
| fender rolling and pulling shops in so cal | SmsAlSuwaidi | Southern California | 15 | 10-08-2013 06:31 PM |
| fender rolling | Andybui82 | Northwest | 0 | 03-30-2013 10:44 PM |
