Drives: 2013 FRS
342whp at 12psi
320whp at 10psi More details here: https://www.facebook.com/OpenFlash-P...3431676670350/ Next step... flex fuel
| The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post: | DustinS (01-29-2016), D_Thissen (01-28-2016), FirestormFlex (01-29-2016), hmong337 (02-05-2016), JonAvalon (01-28-2016), MisterSheep (01-29-2016), NyC Zn6 (01-29-2016), Teseo (01-28-2016), trigger happy (02-01-2017) |
Drives: 2015 Subaru brz
Flex fuel would be amazing
Stock block? Sorry if that's been answered a million times.
Drives: 2013 FRS
Yes, stock block. 100% stock fuel system. Even running the original spark plugs (20k miles).
Drives: WRB Brz / SR S14
I am assuming tuned with the OFT?
Drives: 2013 FRS
How close is flex fuel
Sent from my Nexus 6 using Tapatalk |
Drives: 2013 Ultramarine FR-S
This is amazing. Thank you Shiv@Openflash!!!
Drives: '13 BRZ | '04 E55
Why was the 340whp pull not taken to redline?
#10 |
Drives: 10 Series #974 6m/t
When can we expect to get e85 tune for SBD kit?
| The Following User Says Thank You to NyC Zn6 For This Useful Post: | DustinS (01-29-2016) |
#11 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
Nice results shiv, kind off the same results i'm expecting with the kraftwerks +OFT, but we needed upgraded injectors
![]() i'm interested to see the cam timing maps, as that is what we are still testing to keep more pressure in the block instead of straight out of the exhaust . |
#12 |
Fast enough
Drives: 2013 Subaru BRZ AT
How hard are you leaning on the DI system here to achieve this? Virtually every other tuner I've talked to says above 300whp or so on E85, you really need upgraded port injectors to keep your DI injection time in the correct window for optimum function.
You are quite above that here. |
| The Following User Says Thank You to xsnapshot For This Useful Post: | MisterSheep (01-29-2016) |
#13 |
Killed Scion
Drives: 2013 FR-S Whiteout
Nice job shiv!
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#14 |
| Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
| Nate's SBD/ZAGE Turbo Kit (DYNO Tune) by Bill@Delicious Tuning | 2013GTRNate | Forced Induction | 38 | 05-29-2015 03:15 PM |
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| AT/MT Dyno Results with/without Mods | blackfireball5 | Engine, Exhaust, Transmission | 0 | 07-04-2012 02:34 PM |
