Old 01-28-2016, 12:55 AM   #1
zonda
Drives: 2014 WRB BRZ
Crunchy clutch to a crunchy brake pedal? :(
About a month ago my dealership was kind enough to replace my entire clutch assembly under warranty due to the nasty crunchy TOB. Moving forward to now, my car has developed that same feeling and sound in the brake pedal (although not as bad as the clutch noise).
My '14 BRZ currently has 18.9k miles so I was wondering is it normal to hear the brake pedal make a light crunch noise? or maybe a hissing noise (brake booster)?
I admit the clutch issue made me go crazy whenever I hear an awkward noise in my car now so maybe it is not an issue at all, but I can definitely tell the brake pedal doesn't feel as easy as it once did. My cars pretty much stock except for exhaust.
Anyone with the same symptom develop a fix?
zonda is offline   Reply With Quote
Old 01-28-2016, 01:34 AM   #2
humfrz
I don't have that problem, but, you may consider (in this order):
Checking the fluid level in the brake fluid reservoir , top off if necessary
See of the brake pedal (under the dash) is binding
Maybe bleed the brake system
Have your car's brakes inspected
Then again, maybe it’s just latent crunchy sounds in your brain …..
humfrz
Clutch Pedal rick s Engine, Exhaust, Transmission 51 09-20-2015 10:08 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
Clutch pedal peeping almost? Gillams Issues | Warranty | Recalls / TSB 3 07-22-2014 02:16 PM
Anyone know how to stiffen the clutch pedal? 86main Engine, Exhaust, Transmission 3 03-01-2014 03:45 AM
Moving shifter into reverse is crunchy subiestyle Scion FR-S / Toyota 86 GT86 General Forum 7 02-24-2014 10:16 PM
