Old 02-24-2014, 02:38 PM   #1
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Moving shifter into reverse is crunchy
So moving into first and second are also crunchy, but moving the shifter into reverse is 2 times more crunchy.
The crunchy feeling is just the synchros doing the job?
subiestyle is offline   Reply With Quote
Old 02-24-2014, 03:11 PM   #2
humfrz
Most likely the triple cone synchros just being themselves.
The colder it is, the stiffer they get.
I suggest you be at a complete stop before trying to go into first or reverse.
When going from 1st to 2nd, I find a firm, slow pull helps.
humfrz
Old 02-24-2014, 03:13 PM   #3
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Do you engage reverse while the car is still going forward? Cuz that's real bad for the synchros.
Old 02-24-2014, 05:07 PM   #4
hmkk
I have the same problems as well, just make sure the car/oils are all warm before driving and shifting hard. What I do is cycle through all the gears with clutch in and then start driving, helps with the crunchiness
hmkk is offline   Reply With Quote
Old 02-24-2014, 05:26 PM   #5
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
If I'm not mistaken, the reverse gear doesn't have a synchro.
Isn't that why it tends to be more "crunchy"?
daiheadjai is offline   Reply With Quote
Old 02-24-2014, 09:13 PM   #6
humfrz
Yep, that's my understanding. Ya got three gears playing in reverse mode, one gear on the counter shaft and one gear on the output shaft and a little gear running around in between trying to hook them up. So, everybody has to hold still for a moment before the output shaft starts to go the other way around ...... or something like that .....
humfrz
Old 02-24-2014, 09:52 PM   #7
Porsche
Drives: 2013 BRZ Ltd. MT
Then, you're doing it wrong. Done correctly, shifting into reverse will not produce crunching.
Yes. That's normal to experience severe crunching when shifting into reverse, when done IMPROPERLY.
No.
Synchros actually synchronize the speeds of two gears to be meshed together so that they mesh smoothly and quietly. It's the opposite of what you're thinking. Crunching means the synchros did NOT work as they should.
In the case of our FT86s I don't believe we have synchromesh on our reverse gears. Most cars do not, although some do.
In any case, shift properly and reverse gear will not crunch.
The manual does not appear to explain this properly:
1) Car must be at a complete STOP; the wheels not rolling at all.
2) Depress the clutch pedal to the floor, aka "de-clutch."
3) Wait five seconds (perhaps less, but let's be sure); this allows a geared shaft to come to a stop inside the transmission.
4) Lift the reverse lockout ring on the shift lever, and select reverse gear. It's normal to find that sometimes it won't go in all the way. That's just the teeth landing atop one another, and one simply needs to shift the gear teeth to the side slightly to allow them to mesh properly. We do that by moving the shift lever back to the center, then shift into any other forward gear. This should shift the shaft slightly. Now, try selecting R again. This should work, but repeat as needed.
5) When the gears are allowed to come to a complete stop, reverse may be selected without any crunching.
6) Crunching is as bad as it sounds. So, don't do it.
Porsche is offline   Reply With Quote
Old 02-24-2014, 10:16 PM   #8
Porsche
I believe you are correct. Most, but not all, cars lack any synchromesh on their reverse gears.
Well... sort of.
See my post above, and if I can explain further, let me know.
DIY: ReWire AT Shifter to Reverse & Correct the +/- pattern (on selector stick) ymboc DIY (Do-It-Yourself) Guides 11 04-02-2022 05:07 PM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
Reverse lights not working after Short Shifter install SDIAZ Issues | Warranty | Recalls / TSB 0 01-15-2014 11:12 PM
