Drives: ZN6
Greddy T620z
Hey
Anyone here already running greddy T620z? Whats best way to tune T620z, OFT or EcuTek? |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We've done a bunch of these kits and they work very well. For the price difference it is a no-brainer. We only use EcuTek to tune them. Always a better result than anything else as you have the custom mapping ability and hybrid speed density. With the t620z you can break 300 on pump, get high 300's on e85.
| The Following User Says Thank You to Xero-Limit For This Useful Post: | Toyota86.ir (03-02-2016) |
#3 | |
I'm not looking to build my motor until next summer, but want to get a turbo in a few weeks. So how well does the Greddy T620Z kit work on a stock FRS with upgraded clutch and Greddy cat-back exhaust on 91 octane? |
You got it, stock internals. The 620z will hold 7-8 psi no problem without creep.
#6 | |
Road-hole
Drives: 2013 Whiteout FR-S
look into how boost controllers work.
Jaden |
#7 | |
Drives: White 2014 BRZ
I would think more like mid 400's on e85. Can't the T518z hit nearly 400whp? Maybe I'm getting this confused with the SBD kit.
JDL Turbo kit - Ecutek, HRI tuned.
#8 | |
I want to be able to run the T620z kit on all stock for about a year. I'm assuming the set pressure by the factory wastegate in the T620z is too high for all stock or no? |
#9 | |
Road-hole
nope...
The only way you could would be for the controller to give MORE pressure to the waste gate than the manifold pressure, so it would need a built in pump to increase from the reference off of the manifold pressure, don't see too much call for that to be marketable, when you can just replace a 50 cent spring... For instance, say your waste gate has a 14psi spring in it and you want to run 7 psi boost, you would have to add 7 psi of pressure to the reference in order to open your waste gate and run 7 psi of boost. Jaden I would check the spring for the t620z that you end up with. I wouldn't imagine that a 7 psi spring would be too much for a stock twin, especially if you reference off of the compressor housing because you will have some boost drop before it gets to the manifold if you're intercooled. Last edited by Jaden; 04-29-2016 at 05:23 PM. |
#10 | |
Anyone running it on stock engine? |
#11 | |
Drives: 13 10 series FRS
#12 | |
Road-hole
12 lbs with stock fuel system?
Jaden |
#13 | |
Drives: FR-S TRD RS1#1488
*I've been running 10psi for about 12K miles now and still running strong. definitely get an oil cooler though |
#14 |
No. It's just the turbo and piping. I bought injectors, map sensor, and fuel pump separate. The stock wastegate with the 620z is 12lbs. with the 518z you'd be at 7-8lbs. If you want to stay under 12lbs... go with the 518 over the 620.
| New Greddy T620Z?? | Celigts | Forced Induction | 30 | 09-12-2016 01:49 AM |
| GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 06:09 PM |
