Old 01-25-2016, 08:27 PM   #1
Cuztomizer
Drives: ZN6
Greddy T620z
Hey
Anyone here already running greddy T620z?
Whats best way to tune T620z, OFT or EcuTek?
Cuztomizer is offline   Reply With Quote
Old 01-26-2016, 08:11 PM   #2
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We've done a bunch of these kits and they work very well. For the price difference it is a no-brainer. We only use EcuTek to tune them. Always a better result than anything else as you have the custom mapping ability and hybrid speed density. With the t620z you can break 300 on pump, get high 300's on e85.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Toyota86.ir (03-02-2016)
Old 04-28-2016, 03:14 AM   #3
Eazy-V
Is this on stock internals?
I'm not looking to build my motor until next summer, but want to get a turbo in a few weeks. So how well does the Greddy T620Z kit work on a stock FRS with upgraded clutch and Greddy cat-back exhaust on 91 octane?
Eazy-V is offline   Reply With Quote
Old 04-28-2016, 08:14 AM   #4
Xero-Limit
Xero-Limit's Avatar
You got it, stock internals. The 620z will hold 7-8 psi no problem without creep.
Old 04-28-2016, 05:24 PM   #5
Eazy-V
Ok that sounds great!
How are you lowering/controlling the boost because Greddy said that the wastegate is set on a specific psi and they have no info on the actuator?
Old 04-29-2016, 02:20 PM   #6
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
look into how boost controllers work.
whether mechanical or electronic, boost controllers work by giving the waste gate a lower reference than the actual boost, so even with a 7 psi spring in the waste gate, you can have 20 psi through a boost controller if you want, because regardless what the input to the controller is(determined by what you set it to), the output will be what the waste gate needs to open up.
Jaden
Jaden is offline   Reply With Quote
Old 04-29-2016, 02:54 PM   #7
stevo585
Drives: White 2014 BRZ
I would think more like mid 400's on e85. Can't the T518z hit nearly 400whp? Maybe I'm getting this confused with the SBD kit.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 04-29-2016, 04:57 PM   #8
Eazy-V
Jaden
Ok, that makes sense for increasing boost, but can I lower it from the factory wastegate with a boost controller?
I want to be able to run the T620z kit on all stock for about a year. I'm assuming the set pressure by the factory wastegate in the T620z is too high for all stock or no?
Old 04-29-2016, 05:11 PM   #9
Jaden
Road-hole
nope...
I don't know of any controller that will allow you to run LOWER than spring pressure, you would need to replace the spring with one set for the lowest maximum boost you would want to run then you can use a boost controller to raise it if you want.
The only way you could would be for the controller to give MORE pressure to the waste gate than the manifold pressure, so it would need a built in pump to increase from the reference off of the manifold pressure, don't see too much call for that to be marketable, when you can just replace a 50 cent spring...
For instance, say your waste gate has a 14psi spring in it and you want to run 7 psi boost, you would have to add 7 psi of pressure to the reference in order to open your waste gate and run 7 psi of boost.
Jaden
I would check the spring for the t620z that you end up with. I wouldn't imagine that a 7 psi spring would be too much for a stock twin, especially if you reference off of the compressor housing because you will have some boost drop before it gets to the manifold if you're intercooled.
Old 04-29-2016, 05:17 PM   #10
Eazy-V
Jaden
Ok yeah thats what I was confused about since I heard people are running the T620z kit on stock engine, but Greddy said PSI is set at 15-20.
Anyone running it on stock engine?
Old 04-29-2016, 05:17 PM   #11
fz6r
Drives: 13 10 series FRS
Stock wastegate had me at 12lbs of boost. But I've been running that without any issues. I stay out of boost for the most part. You'll be fine on stock motor. Just make sure to have a conservative tune
fz6r is offline   Reply With Quote
Old 04-29-2016, 05:26 PM   #12
Jaden
Road-hole
12 lbs with stock fuel system?
Does the greddy kit upgrade injectors fuel pump etc? I wouldn't run 12 lbs of boost, conservative or not on a completely stock twin. Most I would run is 8...
Jaden
Old 04-29-2016, 07:19 PM   #13
Crazypinoy9
Drives: FR-S TRD RS1#1488
Jaden
NOPE. but you really don't need to upgrade your injectors unless you're gonna go with e85. at 8psi you'll be more than fine. won't even need to upgrade your pump either. as long as you have a good tuner you can go 10psi on crappy SoCal 91oct for daily use
*I've been running 10psi for about 12K miles now and still running strong. definitely get an oil cooler though
Crazypinoy9 is offline   Reply With Quote
Old 04-29-2016, 07:47 PM   #14
fz6r
Jaden
No. It's just the turbo and piping. I bought injectors, map sensor, and fuel pump separate. The stock wastegate with the 620z is 12lbs. with the 518z you'd be at 7-8lbs. If you want to stay under 12lbs... go with the 518 over the 620.
New Greddy T620Z?? Celigts Forced Induction 30 09-12-2016 01:49 AM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
