| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Brz WRB - Europe LHD
Hi mate, this is the easiest way to install the "FR-S / BRZ Tail as Turn™ +Backup Module" on EDM/JDM grade. http://www.diodedynamics.com/store/c.../category/666/
You need to repin the harnesses this way to obtain same results of USDM tail light. Thus in Europe, we cannot delete turn light, you can preserve this option connecting the two ends of black wire togheter. Therefore, "backup" add-on is not necessary. Here there are two videos of "FR-S / BRZ Tail as Turn™ +Backup Module" installed on Crystal Eye EDM wiring. For running light flashing you need to reverse wiring on EDM schema. Yellow and red wires need to be repinned again in reverse order. Mine is with TapTurn option. When press brake with turn, tail returns to stock operating way. No flash of running light (boomerang) on Crystal Eye. This procedure might be done on Tom's tail light too. Remember that in all schema you will try, Black wire is turn, Green is Ground. One end of black wire will receive 12+ "outside Diode Dynamics one-end module". ![]() ![]() ![]() ORIGINAL DIODEDYNAMICS WIRING USDM ![]() Some video [ame="http://youtu.be/GbI2sfJwMXM"]http://youtu.be/GbI2sfJwMXM[/ame] [ame="http://youtu.be/KSOOVrjyTQw"]http://youtu.be/KSOOVrjyTQw[/ame] WARNING: ON STOCK TAIL YOU NEED TO REPLACE TURN BULBS WITH LED BULBS , FLASHER HIGH CAPACITY (IMPEDANCE) NEEDED
![]() Last edited by Trap63; 01-24-2016 at 10:46 AM. Reason: Diode name checking correction and youtube link |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| [DIY] How To Repin USDM TOM's for EUDM cars | pr0xy | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-06-2015 08:45 AM |
| diodedynamics.com vs. hidkitspro.com | DeviantBlue | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 05-18-2014 10:31 PM |
| DiodeDynamics Lights? | xrinnenganx | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-30-2014 12:09 AM |
| Help Toms JDM repin | hanabie | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 03-29-2014 09:38 PM |
