Old 01-24-2016, 01:19 AM   #1
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Airlift replacement strut
I've torn the bellows on the front left strut and was wondering if anyone out there might know where I might find a replacement strut. I only need the strut body (with functional bellows of course lol) Don't need hub mount, top-hat etc.
I searched Airlift's parts section of their website and found nothing
lukey86 is offline   Reply With Quote
Old 01-24-2016, 11:27 AM   #2
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Email customer service. I believe you can get replacement bags for about $150.
bee_are_zee is offline   Reply With Quote
Old 01-24-2016, 05:35 PM   #3
lukey86
Built Not Bought
lukey86's Avatar
Yeah those bags are for the universal kit, bags on the struts are a one time only deal, can't be swapped so the whole thing needs replacing
Old 01-25-2016, 10:35 PM   #4
Funk
No-Club
Drives: Subaru Brz
Just find the correct size like the billow bag and order it and take off the old one and replace it a buddy of mine did his like that and plus you learn alot more that way
Funk is offline   Reply With Quote
Old 01-25-2016, 10:40 PM   #5
lukey86
Built Not Bought
lukey86's Avatar
The bands are pressed on with a machine, I've looked at removing/replacing them but it's not possible. Plus the only bellows I've found are closed end universal ones, which are a different part number
Old 01-25-2016, 10:59 PM   #6
Cole
Not a troll
Cole's Avatar
Did you think about getting in touch with the manufacturer? I bet they could hook you up
Old 01-25-2016, 11:03 PM   #7
lukey86
Built Not Bought
lukey86's Avatar
Yeah I will eventually, I've noticed there's a lot of resellers of airlift parts so I thought someone here might be able to point me in the right direction, it's cheaper than international phone calls lol
Old 01-30-2016, 05:37 AM   #8
dito
Drives: SWP BRZ
im in the process of ordering a new double bellow bag as well. i contacted airlift and the part number is 58529. u can get them from any airlift dealers from what i was told. @lukey86
dito is offline   Reply With Quote
Old 01-30-2016, 05:39 AM   #9
lukey86
Built Not Bought
lukey86's Avatar
But how the hell would you put it on??? Can't even get the old one off lol
Old 01-30-2016, 05:57 AM   #10
lukey86
Built Not Bought
lukey86's Avatar
Ahhhhhhhhhhh I see!! I didn't know you could just unscrew everything. And this is exactly why I use forums lol
Thanks @dito your a lifesaver let me know how you go with install!
Old 07-08-2016, 12:19 AM   #11
MrPogi86
Drives: RB V3, Supercharged, Bagged
How did you remove the old bellow bag from the strut assembly in the front? I removed the top hat and everything but can't break the threads loose from bottom of the torn bag.
MrPogi86 is offline   Reply With Quote
Old 07-08-2016, 02:54 AM   #12
lukey86
Built Not Bought
lukey86's Avatar
Mine was loose, maybe it's the sealant they use in the factory, if you have access to a large vice you could mount the lower part of the bag in there and use the hub mount as leverage to spin the damper, sounds like it just needs to be cracked hey
Old 07-08-2016, 09:45 PM   #13
MrPogi86
The hub mount and locking collar actually twist downward along the strut if I try to use them as leverage.
Old 07-08-2016, 11:12 PM   #14
lukey86
Built Not Bought
lukey86's Avatar
Yeah I see what you mean, you could take the locking nuts off and screw them back on underneath the hub mount, that way it will all lock in place
Strut Bar Review: AEM Strut Bar Thoughts and Experiences wu_dot_com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-08-2019 05:33 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
Airlift Air Suspension for BRZ/FRS get down low!!! Gruppe-s Brakes, Suspension, Chassis 21 11-25-2014 10:10 PM
airlift suspension? kendalldwhite Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-07-2014 11:56 PM
shock/strut replacement sinigang_guy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-19-2013 10:15 PM
