| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
hey you, yeah you <3
Drives: 2014 37J FR-S
General boxer engine question...
Is it me or do boxer engines produce more steam through exhaust than twin and V engines during idle? Makes no difference if car is hot or cold.
Below is video courtesy of our beloved member @humfrz
Because compromise ®
Drives: Red Herring
Variables that come to mind after 18.4 seconds of consideration.
Size of engine Humidity of ambient air Temperature of ambient air Engine operating temperature between starts. Integrity of head gasket I am suggesting too many variables to answer your question.
#3 | |
Maybe it just looks that way to us, because we like to watch and listen to the exhaust when the engine starts up ..... ![]() humfrz |
#4 | |
not playing cards
Drives: Red Herring
not playing cards
Washed my pickup, then friends 2.5 RS and noticed his exhaust (all stock car) had clouds blowing out of its exhaust when we turned it on, so he asked me to turn on my FRS to compare and same thing! I have TRD exhaust.
Then neighbor's boyfriend came over and he has a SI so we checked his exhaust out and noticed our cars (Subaru's) shoot out/burn out more steam. Got me curious. Temps on cars read 55-57 for outside. I'm sure that was also a factor, but my truck didnt have huge clouds. p.s. his car has 65k miles all stock that he bought from older couple two years ago. He pampers that sob more than his mom. His car has zero issues and does not burn coolant nor oil AFAWK.
Not a troll
I think the important thing here, is to note that resident old man, @humfrz made a ricer exhaust video like a young buck.
Bravo good sir. |
Drives: Full race 4cyl boxer
Horizontally opposed engines notoriously blow smoke at startup.
I have always assumed it was because oil pools on the side of the cylinder when the engine is not running. This allows slightly more oil to pass the rings than a comparable straight or V configuration. VWs and Porsches all do it to some extent. If it is doing it long after startup then it is something else. |
#10 |
Drives: 15' Frs
I have the same problem.(don't know if this is normal) I would start up at 50 degrees and steam would come out, and continue to. Sometimes I would see water underneath my exhaust tips.
#11 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
water means your cats are working good and you are having efficient combustion
#12 | ||
...wait that dont sound right. Quote:
Pumping gas from Chevron does that for me but not Arco or Shell. It probably has to do with mixes they put in there as well. My .02 cents are also on it being a Subaru thing. Will confirm later at work with a Legacy one of my co-workers drives.
#13 |
Drives: Asphalt 2013 FR-S 6MT
My guess is that they don't.. Id say a 4cyl 2.0 boxer makes about the same as any sort of inline 2.0 four. But hey who knows. I know my FR-S bellows a lot of steam on startup.
EDIT: for sure not a problem though. Looks like everyone is doing it
OFT Stage 2 tune, OFH, Works AB-M, Perrin 2.75" Intake/Silicone inlet
Kartboy Short Shifter, WC Lathewerks knob, MTEC springs TSW Nurburgring, FIVE:AD aero kit, smoked Valenti |
#14 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
I wonder if its related to exhaust piping design? Our overpipe goes up a bit before coming back down to the midpipe right? Maybe all the water from cats and whatnot pool there after we shut off engine.
| general question | Stewie | BRZ First-Gen (2012+) — General Topics | 39 | 04-12-2015 08:57 PM |
| What happens on a Boxer engine when there's too much Oil? | @Art_Mighty | Engine, Exhaust, Transmission | 29 | 06-15-2014 04:36 PM |
| Boxer engine and temps | SlinkyAvalanche | Engine, Exhaust, Transmission | 9 | 03-27-2014 03:00 PM |
| Next Gen Boxer Engine 4U-GSE | WingsofWar | Engine, Exhaust, Transmission | 33 | 12-10-2011 12:04 AM |
| Could this be the base FT-86 boxer engine? | iff2mastamatt | Engine, Exhaust, Transmission | 2 | 02-10-2011 10:55 PM |
