Trunk bracing for functional wing
Hey guys,
Going to be installing a trunk-top mounted wing for next season and was looking into reinforcing my trunk a bit. Essentially, I'm trying to figure out if I can mount something to "butt against" the downward force of the wing to help add rigidity to the trunk (prevent lifting of the leading edge) 1) First idea is to put rubber butts in upward direction, mount it to frame somewhere near the tailights so it will be pushing up against the underside of the trunk 2) 2nd idea is to put butts on trunk in downward direction similar to this: ![]() Thoughts / experiences? Thanks!
What wing are you planning on using?
Drives: FRS hot lava
Sorry to bring this back from the dead but what are people doing for trunk reinforcement for real wings?
Drives: 2015 Raven FRS
I made my own mounts for the back of the trunk for my GT 250 wing as I believe this is less flexible than the top.
| The Following User Says Thank You to Lunatic For This Useful Post: | StegaDragon (02-18-2017) |
#7 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Inside-the-Trunk Supporting Structure (bolted to the frame rail, the floor, and the back of the trunk) ![]() Mounted Wing with the Decklid Removed ![]() Mounted Wing with the Decklid in Place ![]() Just for grins, this is the data for the SM203 (note: I ran the wing flat):
I can't do that per my classing rules the trunk has to operate as normal. I seen voltex has a cf reinfor ment but I can't find a place to buy it with out buying the wing too
A support of the type in the first photo won't require the operation of the trunk lid to be modified, and it will certainly support a "real wing".
| Trunk Swap (My trunk w/ Limited spoiler to non wing) SWP | Kuujo | Southern California | 4 | 09-18-2015 01:34 PM |
| Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) | Iamthebatman | Exterior Parts (Aero, Lighting, Etc.) | 2 | 07-18-2013 02:12 PM |
| WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing | wollview | Exterior Parts (Aero, Lighting, Etc.) | 1 | 12-30-2012 03:14 PM |
| WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing | wollview | Southern California | 0 | 12-16-2012 02:46 AM |
