Old 01-18-2016, 12:24 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Trunk bracing for functional wing
Hey guys,
Going to be installing a trunk-top mounted wing for next season and was looking into reinforcing my trunk a bit.
Essentially, I'm trying to figure out if I can mount something to "butt against" the downward force of the wing to help add rigidity to the trunk (prevent lifting of the leading edge)
1) First idea is to put rubber butts in upward direction, mount it to frame somewhere near the tailights so it will be pushing up against the underside of the trunk
2) 2nd idea is to put butts on trunk in downward direction similar to this:
Thoughts / experiences?
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 01-18-2016, 03:23 PM   #2
CSG Mike
CSG Mike's Avatar
What wing are you planning on using?
Old 01-18-2016, 03:38 PM   #3
1Cor10:23
1Cor10:23's Avatar
GTC 200
Old 01-18-2016, 03:42 PM   #4
CSG Mike
CSG Mike's Avatar
Originally Posted by 1Cor10:23 View Post
GTC 200
You won't need to reinforce the trunk for that.
Let us know when you're ready to order!
1Cor10:23 (01-18-2016)
Old 02-17-2017, 10:35 PM   #5
Im_SPEED
Drives: FRS hot lava
Sorry to bring this back from the dead but what are people doing for trunk reinforcement for real wings?
Im_SPEED is offline   Reply With Quote
Old 02-18-2017, 07:48 AM   #6
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I made my own mounts for the back of the trunk for my GT 250 wing as I believe this is less flexible than the top.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
StegaDragon (02-18-2017)
Old 02-19-2017, 01:41 PM   #7
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Below is an example of what a race shop made up for me on a different car that had an SM203 wing mounted to it. While the wing's uprights went through the Kevlar decklid, the principle is the same: wing support strong enough that the car can be pushed by the wing without deflection.
Inside-the-Trunk Supporting Structure (bolted to the frame rail, the floor, and the back of the trunk)
Mounted Wing with the Decklid Removed
Mounted Wing with the Decklid in Place
Just for grins, this is the data for the SM203 (note: I ran the wing flat):
dradernh is offline   Reply With Quote
Old 02-19-2017, 10:34 PM   #8
Im_SPEED
I can't do that per my classing rules the trunk has to operate as normal. I seen voltex has a cf reinfor ment but I can't find a place to buy it with out buying the wing too
Old 02-19-2017, 10:44 PM   #9
dradernh
A support of the type in the first photo won't require the operation of the trunk lid to be modified, and it will certainly support a "real wing".
Trunk Swap (My trunk w/ Limited spoiler to non wing) SWP Kuujo Southern California 4 09-18-2015 01:34 PM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 02:12 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Exterior Parts (Aero, Lighting, Etc.) 1 12-30-2012 03:14 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Southern California 0 12-16-2012 02:46 AM
