Old 01-17-2016, 03:01 AM   #1
kzale1249
Drives: 2015 Scion FRS
Catless Headers CEL??
Hi guys, I'm planning to get a catless headers (possibly tomei uel) combined with Berk catted front pipe and a invidia n1 catback. Will the CEL light come on due to that fact that the headers are catless?
Please reply, thanks a lot!
kzale1249 is offline   Reply With Quote
Old 01-17-2016, 06:36 AM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
Yeah, unless you get a proper tune.
Or an 02 spacer. (Not the best option)
Old 01-17-2016, 06:43 PM   #3
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Maybe not right away but it will. A tune is a definite fix. You could get an 02 spacer but they don't always work
wise345 is offline   Reply With Quote
Old 01-17-2016, 09:28 PM   #4
seant2h
Drives: 2013 BRZ 6MT LTD
I have not yet tuned my car and never tried a spacer and my experience is that when I had a borla el installed I would get a cel every 1000 or so miles and now I've had a JDL UEL installed for 3000+ miles and it has yet to throw a CEL and I have this hooked up to a nameless catted op/fp and q300.
seant2h is offline   Reply With Quote
Old 01-17-2016, 09:31 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yes like said above you will 100% get a CEL.
My advise would be do not install your header until you have cash to tune. Do both at the same time.
Old 01-17-2016, 09:45 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
As everyone else said you will get some code like P0420 or P0421 or something similar because of the O2 sensors after where the cat would have been reading different values than stock. A tune will disable those codes and allow "emissions readiness", and in some jurisdictions like here in buck county PA without a visual check you will pass inspection.
Old 01-17-2016, 10:47 PM   #7
kzale1249
Do you know of any tune that would work best? Would open flash tablet work? I'm fairly new to these stuff. Or there are other tunes that you would recommend.
Old 01-17-2016, 10:51 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
If your new to it go open flash table it will probably be easier for you. Do a little reading on here first. Personally I run ECU Tek
Old 01-17-2016, 10:56 PM   #9
Ashikabi
Ashikabi's Avatar
Ecutek or open flash tablet
Old 01-21-2016, 07:32 PM   #10
witz
Drives: all mine
https://www.privatelabelmfg.com/prod...el-fix-adj.htm
this should work
witz is offline   Reply With Quote
Old 01-21-2016, 08:13 PM   #11
steve99
For a car with just basic mods like header oft will be fine
Device comes with free tunes for variety of mods and petrol 91 93 and e85 tunes
Its readly good if you dont have a local tuner as you flash you own tunes.
If you do have a local tuner then ecutek is about same price as you wont need the cable
See basic bolt on mods link below
Old 01-21-2016, 09:59 PM   #12
wise345
wise345's Avatar
theres several tuners near me. what exactly would i need if i went ecutek? i have the same issue
Old 01-21-2016, 10:13 PM   #13
steve99
Talk to the local tuner to see if pricing competitive
They should be albe to do NA tune and licience for about 600 thats for flash and go tunHave all your mods installed or talk to thner re mods
All you will need is money
Old 01-21-2016, 10:18 PM   #14
Ashikabi
Ashikabi's Avatar
I got my tunes from Delicious. Never have to pay for dyno time, they already know what changes need made for what mods. They claim putting it on a dyno would only net a couple more horsepower
catless, uel header
WTB: Catless headers, EL or UEL Sciontist__ Canada Classifieds 0 09-30-2015 05:45 PM
Catless headers in PA speeddemon NY / NJ / CT / PA 5 01-05-2015 09:42 PM
Catless Headers D.Scrye Mid-Atlantic 11 10-02-2014 11:35 AM
E test with catless headers thunderlights CANADA 4 05-07-2014 09:18 PM
gains from catless headers? Gilwith1l Engine, Exhaust, Transmission 12 04-03-2014 09:26 PM
