Old 04-02-2014, 06:43 PM   #1
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
gains from catless headers?
Is there any noticeable gains to be had by running a catless header vs. A header with a high flow cat on a N/A application on our cars
Gilwith1l is offline   Reply With Quote
Old 04-02-2014, 07:35 PM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Yes
Old 04-02-2014, 08:07 PM   #3
Gilwith1l
Gilwith1l's Avatar
That's it?
Old 04-02-2014, 08:35 PM   #4
ATL BRZ
ATL BRZ's Avatar
That's it?
Yes, there are noticeable gains to be had from a catless header over those from a catted header, all other things being the same in a controlled environment. Cats are inherently restrictive and removing them will increase exhaust velocity and when properly tuned, the engines performance figures can be increased significantly.
The reason nobody else is responding to your inquiry is because there is already a wealth of information and a bunch of threads directly related to your question on this forum.
The search feature is your friend.
Old 04-02-2014, 09:26 PM   #5
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I would say it depends on the header. With the P&L header there was a 4-5 hp difference.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 04-02-2014, 09:40 PM   #6
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Atl was referring to higher hp application. Not the standard na bolt on stuff.
Old 04-02-2014, 09:48 PM   #7
ATL BRZ
ATL BRZ's Avatar
No, I was speaking in general which also applies to n/a applications. Most cold air intakes yield around 5whp gains and everyone who installs those say it's noticeable, which is literally all the OP asked about regarding headers.
Old 04-02-2014, 09:52 PM   #8
tahdizzle
So elite I'm 1338
In na applications cat vs no cat is not a material difference.
Old 04-02-2014, 11:01 PM   #9
Gilwith1l
Gilwith1l's Avatar
Thanks alot
Old 04-03-2014, 03:51 PM   #10
kuhlka
Drives: 2013 BRZ Limited AT
Stock header vs Rev Works UEL on my car after tuning yielded 180whp (4th gear). I think it was about a 15whp gain over stock. The only other change was a K&N panel filter. VERY noticeable change in power.
All of the NA header comparisons I've seen have had a few horsepower variance, but maybe 5whp tops between aftermarket catted vs uncatted. The main things to consider are your state's emissions laws and the sound you're looking for.
kuhlka is offline   Reply With Quote
Old 04-03-2014, 04:46 PM   #11
Tainen
Drives: First SWP BRZ-L
The difference really isn't in the restrictiveness of the cat, since a good header with cat would hopefully have a pretty high quality cat in it. The real issue is that it limits the ability for the manufacturer to get the right runner lengths that really give this car the proper design. So yes, there is a difference, and it's most likely design related and not cat related, from what I've read. And yes, this is talked about extensive on the forums, and I'm kind of tired of the 4+ new header question threads a week that are all clearly documented in many threads. Read the stickies.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 04-03-2014, 09:23 PM   #12
Gilwith1l
Gilwith1l's Avatar
thanks I have been on here a long time trying to get info and I totally overlooked the stickies
Old 04-03-2014, 09:26 PM   #13
Gilwith1l
Gilwith1l's Avatar
Thanks for the not giving me a non pretentious answer like some other people.exactly what I was looking for
Experience w/ Catless Headers? leicaboss Northern California 28 02-07-2014 03:57 AM
Possible whp gains kjdd787 Engine, Exhaust, Transmission 59 01-02-2014 11:59 AM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
Which headers? Borla Equal Length or FA20club catless? Norcalmav23 Engine, Exhaust, Transmission 5 05-25-2013 04:59 PM
ECU HP gains? ender2664 Engine, Exhaust, Transmission 45 03-31-2013 03:33 PM
