Old 01-16-2016, 04:12 AM   #1
golemslord
Drives: 2014 White FRS
Difficult downshifting to 2nd gear
Anyone have this problem from downshifting 3rd to 2nd? There's always seem to be something clunky, making it "hard" to put in 2nd from 3rd?
golemslord is offline   Reply With Quote
Old 01-16-2016, 04:33 AM   #2
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
I've honestly never tried, I usually just downshift as far as third but don't bother going further because the low speed defeats the purpose. If your going a little too fast it can certainly be clunky but low speed should be pretty smooth.
lukey86 is offline   Reply With Quote
Old 01-16-2016, 05:17 AM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Nope, very smooth for me. Just need to rev higher. 👍 about a little more then a thousand rev higher. O.O
Old 01-16-2016, 05:18 AM   #4
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
indeed, rev higher. I go to 2nd from 3rd when I'm at 44-42 dropping and it requires some revs.
nova.86 is offline   Reply With Quote
Old 01-16-2016, 06:19 AM   #5
lukey86
Built Not Bought
lukey86's Avatar
Why would you rev a synchro box?
Old 01-16-2016, 07:10 AM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
O.o I even double clutch on cold mornings.
The Following User Says Thank You to chaoskaze For This Useful Post:
Ultramaroon (01-16-2016)
Old 01-16-2016, 07:11 AM   #7
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Synchros only eliminate the need to double clutch, but rev-matching is still needed for a proper downshift. Rev-match downshifting reduces stress on the drivetrain, prevents forward weight transfer, and reduces chances of wheel lock.
Going from 3rd to 2nd can be done smoothly as long as you rev-match properly, although it is a little more difficult to get smooth compared to downshifting from other gears (6 to 5, 5 to 4, and 4 to 3).
NLSP is offline   Reply With Quote
The Following 2 Users Say Thank You to NLSP For This Useful Post:
firemedic1428 (01-27-2016), nova.86 (01-16-2016)
Old 01-16-2016, 07:21 AM   #8
shellslinger
Drives: Whiteout FRS
My 3rd to 2nd is butter smooth as long as give it enough revs
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
Teseo (01-16-2016)
Old 01-16-2016, 07:23 AM   #9
lukey86
Built Not Bought
lukey86's Avatar
If your on a track trying to squeeze every last inch out of the car yes, but on the road it seems pointless to downshift so aggressively that shock loading the transmission/engine would be an issue.
Old 01-16-2016, 07:44 AM   #10
http://www.ft86club.com/forums/showthread.php?t=31929
http://www.ft86club.com/forums/index.php
http://www.ft86club.com/forums/showthread.php?t=60136
http://www.ft86club.com/forums/showthread.php?t=48560
Old 01-16-2016, 07:44 AM   #11
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
There's more shock on the drivetrain from not properly matching your engine and trans RPM. Rev matching is literally the exact opposite of shock loading.
Also Tcoat doesn't sleep. Fact.
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
chaoskaze (01-16-2016)
Old 01-16-2016, 07:55 AM   #12
lukey86
Built Not Bought
lukey86's Avatar
And my point is that if your downshifting so aggressively that shock loading is an issue then you're either on a racetrack or doing something illegal lol
Old 01-16-2016, 08:03 AM   #13
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I dunno, I always rev match. I even rev match when I'm going from the bottom of 3rd to 2nd. It's less driveline stress any way you slice it, and it's certainly smoother. The balance upset that relying on the synchros causes really bothers me though, but to each his own.
Old 01-16-2016, 08:05 AM   #14
Teseo
Drives: frs
Rev match is the key and also is more fun
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 06:59 AM
Gear grind downshifting from 6th to 5th JarredH Issues | Warranty | Recalls / TSB 6 03-21-2014 03:52 AM
Manual Downshifting to 1st Gear Kundiethala Scion FR-S / Toyota 86 GT86 General Forum 45 08-31-2013 07:08 PM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 09:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 01:20 PM
