Old 01-13-2016, 11:43 PM   #1
g0odspeed
Drives: 2013 Scion FR-S Asphault
Mtec Shiftet Springs
Has anyone had any trouble when installing the Mtec shifter springs from speed factory? I did the driver side no problem, but can't seem to get the passenger side to start without cross threading!! Had to walk away from it for tonight. Their video makes it look so easy, and it really should be. How did everyone else fair when doing this install?
g0odspeed is offline   Reply With Quote
Old 01-14-2016, 12:33 AM   #2
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
You need to clean the green loctite off the threads of the transmission or else you'll end up cross threading and having to retap the hole.. ask me how I know
BAMF86 is offline   Reply With Quote
The Following User Says Thank You to BAMF86 For This Useful Post:
g0odspeed (01-14-2016)
Old 01-14-2016, 12:36 AM   #3
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
The issue for a lot of guys is the locktite in the threads of the trans. Try scraping the excess green locktite out of the threads with a pick, just be careful not to damage the threads.
If you still have trouble, you can remove the front pipe to get more room and a better angle.
The Racers Line is offline   Reply With Quote
The Following User Says Thank You to The Racers Line For This Useful Post:
Old 01-14-2016, 08:29 AM   #4
g0odspeed
Do I dare ask?!?! That's exactly what I don't want to do.. I bet that sucked retapping in that tight spot. Or did worse, did you have to drop your transmission to do it?
Thanks for the info guys. I will work on doing that. Dropping the mid pipe isn't a bad idea at all. More work, but if it prevents the worse case scenario then it's worth it.
The Following User Says Thank You to g0odspeed For This Useful Post:
zc06_kisstherain (01-14-2016)
Old 01-15-2016, 09:20 PM   #5
g0odspeed
Thanks for the help guys. Got everything in without cross threading!! So glad that is behind me.. Now on to the rest of the build.
Yet another Mtec shift Springs review Raven604 Engine, Exhaust, Transmission 19 10-05-2016 08:04 PM
MTEC shift springs grostoine Engine, Exhaust, Transmission 116 03-30-2016 09:42 PM
MTEC shifters springs? BRZHarley Engine, Exhaust, Transmission 2 10-11-2015 05:01 PM
FS: Mtec Shifter Springs unlimited86 Transmission and Driveline 2 08-27-2014 04:19 PM
Mtec Shift Springs 36 shipped. Mr. Transmission and Driveline 8 02-28-2014 10:44 AM
