Old 07-03-2022, 07:14 PM   #141
clio
Drives: 2013 Subaru BRZ
Originally Posted by bradsm87 View Post
Here is a full list of the parts.
Note the front shield change is not needed and you can just cut the rear shield, which saves disassembling other things too.
I've just done this swap in the past few weeks. I used the oem rear dust shields which wasn't too much effort, I didn't like the idea of cut tin around the brake hoses.
clio is offline   Reply With Quote
Old 07-03-2022, 08:54 PM   #142
bradsm87
Drives: It has 4 wheels
Nice. So pretty much undo the big nut, undo the 4 bolts behind the knuckle, and pull the hub out? Is the park brake cable just a matter of wiggling the right way to get it out of the old shield and into the new one?
bradsm87 is offline   Reply With Quote
Old 07-03-2022, 11:21 PM   #143
clio
That's it. The dust shield integrates the parking brake assembly so it is necessary to pull it apart, however I marked the pieces with a coloured pen and it was relatively easy to re-assemble.
When I undid the 4 bolts the hub just fell away, for those that live in corrosive environments the job might be a pain if the hub is rusted on.
Old 07-11-2022, 08:17 PM   #144
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
Originally Posted by Veloist View Post
Diagrams and Part Numbers are now available.
Front Brake Brembo: http://parts.subaru.com/a/Subaru_201...10-262-03.html
Rear Brake 17inch:
http://parts.subaru.com/a/Subaru_201...10-263-03.html
I'm not too much of technician so would anyone be able to chime in on how one would be able to swap the stock brakes to this setup (I'm sure a couple of people are curious)?
Does anyone know the difference between the repair kits?
There are two repair kits listed for the front brakes on that page above:
26297CA001 costs $36.07
26297CA010 costs $142.63
What gives?
I am going to get mine powder-coated to a different color, so I need a repair kit for each caliper. Whats worse, I went to the parts department, and asked them what the difference was, they said "they have no idea". -_-
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 07-11-2022, 10:03 PM   #145
bradsm87
What gives?
The expensive one is for Brembo calipers. The cheap one is for the standard non-Brembo ones.
The parts diagrams can be confusing. Even the diagrams that have Brembo brakes in the title still includes both options in the parts listings.
The Following User Says Thank You to bradsm87 For This Useful Post:
Daedex (07-11-2022)
Old 07-11-2022, 11:55 PM   #146
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
What gives?
I find that the parts descriptions on subarusource.com are more detailed than any other place I've looked. Prices are pretty good also.
2020BRZtS is offline   Reply With Quote
The Following User Says Thank You to 2020BRZtS For This Useful Post:
Daedex (07-12-2022)
Old 04-27-2023, 09:36 AM   #147
imprezive
Drives: 2017 BRZ - WRB - PP
FYI - I just received confirmation from Centric that the performance high-carbon "replacement" rotors for the PP packaged have been discontinued. I ordered them like 6 months and they were still listed on their website/distributor sites as available, but out of stock. Turns out they were actually discontinued.
Part numbers 125.47019 & 125.47043
They do have the C-Tek "standard" rotors available still. Part numbers 121.47019 & 121.47043.
imprezive is offline   Reply With Quote
The Following User Says Thank You to imprezive For This Useful Post:
Pat (04-27-2023)
CSG Brembo Brakes LenA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-28-2022 04:09 PM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
EVO 7 BREMBO FRONT BRAKES ON BRZ? NOTORIOUS.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-26-2016 12:24 AM
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 02:00 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
