#113 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
#114 |
Drives: Skoda Yeti DSG diesel 4x4
#115 |
Drives: Attitude
#116 |
Señor Member
Drives: 2013 SSM DZE BRZ
How easy is it for everyone to downshift into 5th gear? I always encounter some resistance doing so; it never goes in as easily as downshifting to 2nd-4th gear.
#117 |
Drives: White BRZ
Every time I up or downshift into 2nd, there is a very audible thunk and mechanical feeling in the shifter, but no grinding. I also have to let off the clutch slower than all the other gears or it'll be a very jerky shift, and this happens whether the car is cold or warm. Every other gear is fine
| The Following User Says Thank You to moK For This Useful Post: | LeeMaster (12-30-2012) |
#118 | |
#119 |
Subaru product specialist
Drives: BRZ Sportech
Trans flush to Pentosin MTF-2 is the solution, it's like
butter even in the coldest weather (Montreal) Feels like a diiferent transmission now, smooth with no restrictions at all. |
| The Following User Says Thank You to Bluetib For This Useful Post: | Cameronghanson (12-30-2012) |
#120 |
Drives: 2013 Scion FR-S 6-speed whiteout
Transmission syncros
I've been having the same problem with my first and second gears too. Bought my fr-s about a month ago. It has about 800 miles on it and it is definitely something wrong. Mine seems to be particularly bad on first drive, when car is cold and has been sitting. Has anyone took their's to the dealership to get it checked out?
#121 | |
Change the oil for Pentosin MTF-2 as suggested, I will on mine when the weather cools down. Just for the record. I picked up my GTS86 manual on Xmas Eve and have clocked just over 1000km. I can snick it into 1st gear while it's moving without any problems at 20kph. No double clutching to rev match, just shove it from 2nd into 1st and let the clutch out. There have been many posts saying you can't, shouldn't shift into 1st unless it's stationary and it's a load of old cobblers. |
#122 |
Drives: n/a
i switched all my diff fluid and tranny fluid to redline and it fixed all of that. all of my BMWs and MINIs felt the exact same way until i switched out the fluids
#123 | |
Great! They sell it just up the road, 20km away. 3.78L of MT-90 is $168! Last edited by sierra; 12-30-2012 at 11:14 PM. |
#124 | |
Drives: '13 Ultramarine
The preferred weight for the rear diff is 75W85. Here is a link to the proper weight Redline oil... http://www.redlineoil.com/product.aspx?pid=40&pcid=4 75W85 is fairly common in the Toyota world, and may be in stock at your local Toyota dealer. 75W90 GL5 is also acceptable for the rear end, and may be easier to find.
#125 | |
I'll chase up the Pentosin on Wednesday. It should be in stock at the dealers. Thanks for the info. If i change the diff oil too I want to get a good fully synthetic oil. It seems to be the theme that they didn't exactly break the bank with the oil they used in the Subaru factory For anyone in Oz also looking there's a couple of local oils with good reputations that might also be ok. Both fully synthetic. This one over in Queensland with the Gear SYN 7590. http://www.synforce.com.au/gear_oils.html Scroll down Also Penrite Pro Gear 75w-90 which I have in my Triton and after trying several is by far the best. http://www.penriteoil.com.au/product...d_products=376 |
#126 |
Drives: n/a
That's awful mate. Way to expensive there but if you did want to go that route, on redlines website you put it the make and model and it will find you all the right fluid. Either way, redline or not, changing the fluid seems to be the way to go. Especially tranny fluid.
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 07:07 PM |
| A problem with new rules in SCCA/NASA regarding FIA seats | CyberFormula | Other Vehicles & General Automotive Discussions | 3 | 11-09-2011 09:13 AM |
| Help me track down my braking problem :( | #87 | Other Vehicles & General Automotive Discussions | 32 | 09-26-2011 12:49 PM |
