Old 03-10-2015, 08:34 PM   #113
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by D_Thissen View Post
I was just about to ask, what tires would people suggest as a next step from the OEM ones?
I would like a bit better overall grip, with out loosing the character of the car. I guess I'm asking if the OEM tires are a 2 out of 10 on the 'grip-o-meter' what tire(s) would fall in the 5 out of 10 category??
Like @strat61caster said, check TireRack.com.
I've had 225/45 RE-11A's and PSS's on stock wheels. The PSS's come closer to your requirements and are far better in the wet than the RE-11A's. Also, being lighter, they accelerate a little better than the Bridgestones. The RE-11A's do everything else better if you're looking for a no compromise tire.
The big negative that both fall off drastically below 50°F.
Another consideration is that the Michelin's are incredibly loud on almost anything but a racetrack but have a 30K mile treadwear warranty, unusual for a Maximum performance tire. The Bridgestones and all the other Extreme performance tires have no mileage warranty.
If I lived there and wanted a year-round performance tire, I'd pass on both of those and keep looking.
Ideally, you could run the 225/45 RE-11A's on stock wheels for three seasons and then switch to narrower, dedicated snows on steelies (see @Tcoat) for Winter.
torqdork is offline   Reply With Quote
The Following 3 Users Say Thank You to torqdork For This Useful Post:
Sarlacc (03-10-2015), strat61caster (03-10-2015), Tcoat (03-10-2015)
Old 03-10-2015, 08:46 PM   #114
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
OH god
Yes, my son?
Old 03-10-2015, 08:50 PM   #115
Originally Posted by jsimon7777 View Post
Yes, my son?
Oh sorry! Wrong number.
Ultramaroon (03-13-2015)
Old 03-13-2015, 09:13 AM   #116
Felix7007
Drives: Scion FR-S Black
Michelin Super Sport 225/45R17 will change your life and save you money
Felix7007 is offline   Reply With Quote
Old 03-13-2015, 06:51 PM   #117
ducky369
Drives: 2014 Frs
Quick question, what's the best psi on the stock wheel? Inside the car said 35?
ducky369 is offline   Reply With Quote
Old 03-13-2015, 09:51 PM   #118
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
depends on your area, temp, altitude, type of driving, type of weather conditions, and color of your car. I keep mine at 42psi, and have gotten pretty even tire wear. It is a little harsher, but better mpg on the hwy. I believe you get better grip in low traction conditions(rain/dirt) with lower pressure.
Old 03-14-2015, 02:56 AM   #119
donoman
donoman's Avatar
Drives: '13 FR-S
i want a quieter tire.
I want a stickier tire.
I want the same MPGs.
Cost and Durability are no issue.
Are PSS this tire?
donoman is offline   Reply With Quote
Old 03-14-2015, 03:26 AM   #120
EAGLE5
Dismember
EAGLE5's Avatar
Originally Posted by donoman View Post
i want a quieter tire. Nope
I want a stickier tire. Yup
I want the same MPGs. Nope
Are PSS this tire? Nope.
We can't always get what we want.
Old 03-14-2015, 03:30 AM   #121
ducky369
Drives: 2014 Frs
I live in NorCal, just like the cities, flat road. Driving half 60% freeway 40% local maybe even 70/30 what would you recommend? No high altitude, usually nice weather. Minimal rains, zero snow. I think I keep mine at like 30?
Old 03-14-2015, 03:35 AM   #122
But if we try sometimes we just might find...
Old 03-14-2015, 03:39 AM   #123
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I don't get it
Old 03-14-2015, 03:46 AM   #124
I don't get it
Too young then!
The "old" guys will.
navanodd (04-07-2015), Stewie (03-18-2015)
Old 03-14-2015, 04:27 AM   #125
Target70
Target70's Avatar
I believe 30 is a little low. It might feel squishy/sluggish when you try to turn quickly (like when dodging debris on the highway) not to mention lower miles per gallon, but as long as your tires are wearing evenly, it is really up to your preference, you should try out different pressures and see which ones you like. Here is some quick info, I didn't intend to go to a prius site, I just clicked on a picture on google to show the tire wear patterns based on pressure and it brought up that page. http://priuschat.com/threads/best-ti...r-prius.84879/
So pretty much street driving, no canyon runs, or track days? I would start out at 42 like me. I think the tire limit is 51psi so anything under that should be "safe" unless you have lots of potholes and crappy roads. Ride quality will get harsher as the pressure increases, especially at higher speeds or on rough roads, but I think between 40-45 is a good starting place.
I don't get it
Too young then!
I don't care how young someone is, if they are old enough to type, I can't comprehend them not getting that reference. It's like not knowing we went to the moon.
[ame="https://www.youtube.com/watch?v=8zgAWHRJC1Y"]You Can't Always Get What You Want - The Rolling Stones - YouTube[/ame]
The Following User Says Thank You to Target70 For This Useful Post:
Tcoat (03-14-2015)
Old 03-14-2015, 04:33 AM   #126
Andrew025
Andrew025's Avatar
Too young then!
I believe 30 is a little low. So pretty much street driving, no canyon runs, track days? I would start out at 42 like me. I think the tire limit is 51psi so anything under that should be "safe" unless you have lots of potholes and crappy roads. Here is some quick info http://priuschat.com/threads/best-ti...r-prius.84879/ Ride quality will get harsher as the pressure increases especially at higher speeds or on rough roads, but I think between 40-45 is a good starting place.
I don't care how young someone is, if are old enough to type I can't comprehend them not getting the reference, It's like not knowing we went to the moon.
I still don't get it
Didn't Sputnik beat us?
The Following User Says Thank You to Andrew025 For This Useful Post:
Tcoat (03-14-2015)
Stock FRS Wheels with New Stock Tires gbgracer Wheels and Tires 2 10-05-2014 03:38 AM
FS: 2x stock rims with stock tires $120 retrosmiths Wheels and Tires 21 04-13-2014 03:20 AM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
stock tires on 17 x 9 andrew5826 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 11-11-2013 11:26 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
