Old 11-09-2013, 06:51 PM   #1
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
stock tires on 17 x 9
looking to change my wheels but tires still have life in them. will the stock 215 tires fit on a 17 x 9 rim?
17 x 9 5/100 35 mm
http://www.1010tires.com/Wheels/Fast...90-80GT-35C730
andrew5826 is offline   Reply With Quote
Old 11-09-2013, 07:17 PM   #2
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
it will fit but you'll be hella stretched which is retarded
bkblitzed is offline   Reply With Quote
Old 11-09-2013, 07:20 PM   #3
Suberman
Drives: Subaru BRZ Sport Tech Satin White
17 x 9 5/100 35 mm
No, they will be unsafe. There is also no reason to fit 9 inch wide wheels to this car. Wide wheels do not improve handling although many think they do.
http://www.carbibles.com/tyre_bible_pg4.html
Scroll down to the rim size calculator.
Also the stock tires are junk when new. Don't try to save them they are just awful tires for this or any other car. Maybe they'd be good on a "sport" Prius but that's an oxymoron anyway.
Suberman is offline   Reply With Quote
Old 11-09-2013, 07:25 PM   #4
bkblitzed
is better than you
bkblitzed's Avatar
The stock tires aren't as bad as many people think
Old 11-09-2013, 07:35 PM   #5
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
It doesn't improve handling but it does improve grip, which is very good if you are tracking or autocrossing the car. Plus with fatass tires, the car looks so good!
IAmNotTheDriftKing is offline   Reply With Quote
Old 11-09-2013, 08:01 PM   #6
fatoni
they probably wont be unsafe. there is absolutely reason to go to a nine inch rim. the tires arent awful. all that being said, it doesnt seem smart and sounds like more work than its worth
Old 11-09-2013, 08:14 PM   #7
df.dima
Drives: FR-S and Mazda 3 Sky
Check out DarrenDriven's old topics [edit: he put on other brand tiers, but in similar size, so not exactly what you want, it was pretty stretched.]
There are a few more people that did that. Way too stretched imo.
Here you go, spot on, stock tires on x9 wheels:
http://www.ft86club.com/forums/showt...t=39241&page=2
df.dima is offline   Reply With Quote
Old 11-09-2013, 08:57 PM   #8
utekineir
blowhard
Drives: frs, project forester
Depends on wether you got michelins or the Bridgestone turanzas.
utekineir is offline   Reply With Quote
Old 11-09-2013, 08:58 PM   #9
bkblitzed
is better than you
bkblitzed's Avatar
i got the michelins
Old 11-09-2013, 09:20 PM   #10
Mitch
form follows function
Drives: RIP '13 BRZ
You're right that stretching the stock tires onto 9" wheels would be silly, but 9" wheels with 245 width tires is actually ideal for this chassis, at least for people who autocross/track their cars.
Mitch is offline   Reply With Quote
Old 11-09-2013, 09:54 PM   #11
Suberman
No, they're worse than anybody thinks. For this car. They have their place, just not on this car.
Old 11-09-2013, 09:58 PM   #12
Suberman
Well, maybe. Wide tires don't work the way people seem to think they work. Grip is limited by the coefficient of friction. Tire width affects how that grip is utilized. Tire width doesn't change the maximum grip available.
This is often misunderstood by non experts seeking to improve vehicle performance. The ideal tire size for this car is probably 225/40 x 18.
245/40 x17 would be close to stock size but the narrower 18 in would be quicker.
Old 11-09-2013, 10:40 PM   #13
Gunman
Drives: 2019 Mazda Miata RF
Tire width affects the shape of the tire contact patch, not the size of it (for a similar tire construction and pressure).
Gunman is offline   Reply With Quote
Old 11-09-2013, 11:37 PM   #14
utekineir
blowhard
i got the michelins
you lucked out
sadly, the turanza score is actually improved, earlier this summer it was pretty much all pink and red
WTB Your Stock Tires touge-n00b Hawaii 0 10-27-2013 03:01 PM
stock tires fitcious Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 59 09-22-2013 08:04 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
OMG the stock tires... luscious Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-01-2012 09:34 PM
Stock tires arcinthesky CANADA 17 06-08-2012 06:52 PM
