Old 04-02-2013, 09:52 PM   #113
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
just put the pick up on one of the black wires going to the coil packs, easy to find on passenger side
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Sportsguy83 (04-03-2013)
Old 04-02-2013, 10:50 PM   #114
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is where we picked it up, and I watched them change some settings on the dyno, but it still apparently didn't read RPM correctly. The same thing happened on my dyno plot from Titan Motorsports where it only shows the motor reving to 6500 RPM instead of 7500 RPM. Where did that last 1000 RPM and first 1000 RPM go?
Old 04-02-2013, 10:57 PM   #115
sw20kosh
Drives: 2013 Black FR-S
Could all these issues be caused by bad ignition parts or a bad ground? Could that be why the pick up is bad too?
On a previous vehicle boost and torque would get choppy and taper down. Found out later on that my coil pack or something was bad.
Old 04-02-2013, 11:27 PM   #116
crook
crook's Avatar
Drives: storm black GT
Yeah definatly swap the MBC for an EBC I had never ending issues with spikes and tapering off due to my old MBC
crook is offline   Reply With Quote
Old 04-03-2013, 12:23 AM   #117
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Chris, You shouldn't have to run that much boost. Just look at your 8 psi curve compared to your 14psi. Looks to me that it needs more timing in it.
A motor that runs too much retard is just as bad as one that runs too much advance.
You cannot properly tune ignition timing on the street.
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
NorCalRider (04-03-2013)
Old 04-03-2013, 09:03 AM   #118
Visconti
Drives: 05 STi
Recently I've done a few more of these setups and have been able to run more ignition timing with high boost. im starting to wonder if all that blow by you've had since day one is something more serious.
That aside Im ust happy your car cold and hot starts correctly now
Send over some updated datalogs when you get a chance, include the cruise control stuff we discussed
Car won't accept anymore timing with out knocking.
Turning the boost down and raising the timing just caused more knock.
It clear that who ever put the car on the Dyno didn't load it up correctly..
Wavy dynosheet isn't from a lack of timing but from how the car is strapped.
Wish a datalog could have been produced when the car was on the Dyno and I hope some day we can see full dyno run.
A simple EBCS can be hooked up to prevent boost spikes and boost drop off.
When I was street tuning the car I had suggested putting in a larger spring.
That being said, you can 100% properly tune ignition timing on the street...
John
Visconti is offline   Reply With Quote
Old 04-03-2013, 11:10 AM   #119
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I have to admit that when you look at the run from Titan Motorsports with a smoothing of 3 and the HP curve looks super smooth compared to my dyno at XXX Motorsports with the smoothing set even higher at 5. I also noticed that the HP curve didn't start looking really wavy until after around 5500 RPM when I set the smoothing to 1. I will push Will at Titan to see if I can get those dyno run files again so I can plot the runs together.
Old 04-03-2013, 11:13 AM   #120
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Your street tune definitely improved the driveability. I will do a datalog specifically for the only remaining drivability issue I am having. I am also getting a 10 psi spring for my wastegate and will try running off just that to compare my boost curve, then I will try an electronic boost controller to see if it can improve the curve even more.
The Following User Says Thank You to King Tut For This Useful Post:
Old 04-03-2013, 11:17 AM   #121
Visconti
Drives: 05 STi
Sounds like a plan !
-John
The Following User Says Thank You to Visconti For This Useful Post:
Old 04-03-2013, 01:33 PM   #122
sw20kosh
John
I said earlier:
And I found a dyno chart. Was running 17 psi but it would taper off to 14 psi. by redline. It got choppy too in the higher rpms. My tuner couldn't figure out why it was doing this as the turbo was BIG, no knock, perfect timing and definitely shouldn't have been losing boost. The car also had terrible cold/warm start up issues. We tried for months to figure it out and in the end I sold the engine. Someone bought it and put it in their car with a new ignition pack (something like that) and it ran beautifully. Made 420 WHP with no loss in boost etc.
(notice how it gets choppy at 5.5k rpm?)
Old 04-03-2013, 01:41 PM   #123
mad_sb
Drives: 2013 Asphalt FR-S
I just clipped the tach lead over both wires on the driver side rear (nearest the firewall) coil pack at both of the dynojets i have used so far and it worked perfectly.
Old 04-03-2013, 08:27 PM   #124
King Tut
NASA SpecE30 Racer
King Tut's Avatar
So I just had a thought as I was taking pictures of the tach signal wire for my AEM Failsafe gauge. Why not next time I go to the dyno just have them hook up to that wire instead of trying to get the signal off the coils? Any reason that wouldn't work?
Sportsguy83 (04-04-2013)
Old 04-03-2013, 08:43 PM   #125
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Great thread...
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 04-04-2013, 12:03 PM   #126
itdansharpe
itdansharpe's Avatar
Dear king tut, I am in the middle of installing this kit, and ran into the threading issue you had with the brass T oil feed. What thread pitch did you run over it to make it fit?
Thanks!
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
blown, fbm, full, king tut, turbo
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 08:39 PM
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 09:27 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 03:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 11:13 AM
