| View Poll Results: Coilovers? | |||
| KW Varient 3 |
160 | 47.20% |
| BC (what varient should I get?) |
48 | 14.16% |
| HKS Hipermax IV GT |
21 | 6.19% |
| Cusco (what varient should I get?) |
15 | 4.42% |
| KSport Kontrol Pro/D2Racing RS |
10 | 2.95% |
| Megan |
12 | 3.54% |
| Tein (what varient should I get?) |
54 | 15.93% |
| Tanabe Sustec Pro |
1 | 0.29% |
| Stance |
18 | 5.31% |
| Voters: 339. You may not vote on this poll | |||
#113 |
Drives: Scion FRS
Would the GC coils fit with the PJDM strut tower combo?
http://passwordjdm.com/PasswordJDM-U...8629C2570.aspx |
#114 |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
If I was in your situation I'd buy coilover sleeves from Ground Control
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
| The Following User Says Thank You to seven For This Useful Post: | GC_Adam (12-11-2012) |
#115 | |
The cars only have about 3" of bump travel at stock height, so dropping it 2" on stock (or stock length) shocks is going to require very high spring rates to keep it off the bump stops. High spring rates require high dampening rates, which will make it ride like a dump truck on the road.
#116 | |
![]() - Andrew |
#117 |
^^ Even better
#118 | |
Drives: '08 Impreza, 03 SV1000S
Do you already have the PJDM bar? Adam |
#119 |
Kouki-Monster
What are people doing to fix this issue?
Rich Anderson
EMPOWER AUTO |
#120 |
Adam, I got my box from UPS, holy cow. THANKS
I can see travel is not gonna be an issue here.. I need to take another pic to show the thickness of this top plate, wow. Nice billet CNC work Light. Sweet. Purty. Now I just need my car back to install these! |
| The Following User Says Thank You to gmookher For This Useful Post: | dabocx (12-11-2012) |
#121 |
On springs? Unfortunately nothing. You can cut the bumpstops (or a few springs come with replacement stops) but you have to be careful with how that works with the rest of the system. But 2 inches is just too much, even 1.5 IMO is too much.
For those drops you should be using coilovers. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | gmookher (12-11-2012) |
#122 | |
Kouki-Monster
Rich Anderson
EMPOWER AUTO |
#123 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#124 |
#125 | |
F Z1LLA
Drives: Lexus IS-F Series 2
Those GC coilovers look great! I opted for the KW's in the end
2URGSE |
#126 |
Drives: 2013 Firestorm FRS, 97 BMW M3
First, I have absolutely no experience with air suspension. However, I have read a little bit about air suspension, specifically from AirRex. AirRex worked with a shop called Forjworks or something like that for Sema and has a air ride setup for the FRS. I don't know if it is released yet but my limited knowledge of air suspension is that it allows a big drop and with the right settings can maintain a good ride quality. Personally, I'm waiting for the ohlins.
EDIT: Got curious after posting and looked up some air suspension from airrex. It can be expensive! Damn! Not sure what it will end up being for the FRS.
Willow Springs |
| DIY BC coilovers | RWD-boxer | DIY (Do-It-Yourself) Guides | 1 | 11-05-2012 09:07 PM |
| Bc br coilovers | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 10-20-2012 11:44 PM |
| M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS | AMPLIFIED MOTORSPORT | Brakes, Suspension, Chassis | 0 | 08-16-2012 02:45 AM |
| Coilovers vs Springs – What are coilovers and what’s better? | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-30-2012 12:24 AM |
| D2 coilovers | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-27-2012 03:50 AM |
