View Poll Results: Coilovers?
KW Varient 3 160 47.20%
BC (what varient should I get?) 48 14.16%
HKS Hipermax IV GT 21 6.19%
Cusco (what varient should I get?) 15 4.42%
KSport Kontrol Pro/D2Racing RS 10 2.95%
Megan 12 3.54%
Tein (what varient should I get?) 54 15.93%
Tanabe Sustec Pro 1 0.29%
Stance 18 5.31%
Voters: 339. You may not vote on this poll
Old 12-10-2012, 11:57 PM   #113
dabocx
dabocx's Avatar
Drives: Scion FRS
Would the GC coils fit with the PJDM strut tower combo?
http://passwordjdm.com/PasswordJDM-U...8629C2570.aspx
dabocx is offline   Reply With Quote
Old 12-11-2012, 04:03 AM   #114
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
If I was in your situation I'd buy coilover sleeves from Ground Control
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
The Following User Says Thank You to seven For This Useful Post:
GC_Adam (12-11-2012)
Old 12-11-2012, 08:03 AM   #115
wparsons
wparsons's Avatar
Originally Posted by Snoopyalien24 View Post
Ah thanks! I hope to go 1.5"- 2" low, nothing slammed, but nothing too high.
Seems silly to pay $2k for lowering it only if I am never going to track it (imho)
That all depends on how much you value ride quality.
The cars only have about 3" of bump travel at stock height, so dropping it 2" on stock (or stock length) shocks is going to require very high spring rates to keep it off the bump stops. High spring rates require high dampening rates, which will make it ride like a dump truck on the road.
flickr
Old 12-11-2012, 08:43 AM   #116
Racecomp Engineering
A 2 inch drop would put it well into the bumpstops at rest.
- Andrew
Old 12-11-2012, 11:53 AM   #117
wparsons
wparsons's Avatar
^^ Even better
flickr
Old 12-11-2012, 11:55 AM   #118
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
No, this won't work with GC camberplates, however you could still use the GC street system that still uses the OE strut/shock mounts in conjunction with the PJDM combo.
Do you already have the PJDM bar?
Adam
GC_Adam is offline   Reply With Quote
Old 12-11-2012, 12:04 PM   #119
empower-auto
Kouki-Monster
empower-auto's Avatar
- Andrew
What are people doing to fix this issue?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 12-11-2012, 12:05 PM   #120
gmookher
Adam, I got my box from UPS, holy cow. THANKS
I can see travel is not gonna be an issue here..
I need to take another pic to show the thickness of this top plate, wow.
Nice billet CNC work
Light. Sweet. Purty. Now I just need my car back to install these!
The Following User Says Thank You to gmookher For This Useful Post:
dabocx (12-11-2012)
Old 12-11-2012, 12:41 PM   #121
On springs? Unfortunately nothing. You can cut the bumpstops (or a few springs come with replacement stops) but you have to be careful with how that works with the rest of the system. But 2 inches is just too much, even 1.5 IMO is too much.
For those drops you should be using coilovers.
- Andrew
gmookher (12-11-2012)
Old 12-11-2012, 12:45 PM   #122
empower-auto
Kouki-Monster
- Andrew
So if someone was using say an Eibach Pro Kit (1" ish) would they be alright?
Rich Anderson
EMPOWER AUTO
Old 12-11-2012, 01:08 PM   #123
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
- Andrew
Shortened struts.. but yeah no one is doing that yet either for lowering springs.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 01:25 PM   #124
yup.
Old 12-12-2012, 09:58 AM   #125
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Those GC coilovers look great! I opted for the KW's in the end
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-13-2012, 01:05 PM   #126
IShouldStudy
IShouldStudy's Avatar
Drives: 2013 Firestorm FRS, 97 BMW M3
First, I have absolutely no experience with air suspension. However, I have read a little bit about air suspension, specifically from AirRex. AirRex worked with a shop called Forjworks or something like that for Sema and has a air ride setup for the FRS. I don't know if it is released yet but my limited knowledge of air suspension is that it allows a big drop and with the right settings can maintain a good ride quality. Personally, I'm waiting for the ohlins.
EDIT: Got curious after posting and looked up some air suspension from airrex. It can be expensive! Damn! Not sure what it will end up being for the FRS.
Willow Springs
IShouldStudy is offline   Reply With Quote
DIY BC coilovers RWD-boxer DIY (Do-It-Yourself) Guides 1 11-05-2012 09:07 PM
Bc br coilovers whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 10-20-2012 11:44 PM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 02:45 AM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
D2 coilovers F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2012 03:50 AM
