Old 10-30-2012, 10:15 PM   #1
RWD-boxer
RWD-boxer's Avatar
Drives: Black
DIY BC coilovers
DIY
First off let me say I am very happy with the service And price from http://www.jmautoracing.com/join-4752.html
( tell them killer08tc sent you)
new in the box bc coilovers for frs scion by killer08tc, on Flickr
before front wheel gap by killer08tc, on Flickr
Before and after
After drop by Tsmnitti, on Flickr
DIY
I will be posting pic as I edit them!
If you have any more to add to what I did let me know in a pm and I will add any good ideas to the DIY
Jack up front of car and put on jack stands
Remove rims and tires using 19mm
Remove plastic clips holding speed spencer to wheel bearing using needle nose
Remove 12mm bolt holding brake line to strut
front brake line scion frs by killer08tc, on Flickr
Remove two 19mm bolts from lower strut ( when installing new strut one bolt has larger neck , it belongs in top hole)
Remove both nuts on end link ( 17mm with 6 mm Alain head )
better front linkage pic frs scion by killer08tc, on Flickr
Remove top three 12mm bolts on top of strut
top front strut bolts scion frs by killer08tc, on Flickr
Strut will fall out at this point!
Now repeat on the other front strut
Now it's time to pick a ride height , make both sides the same !! Use a caliper or tape measure
Push strut up and into place from bottom and install three 12mm nuts
Use jack to push up lower control arm into place
And install lower strut bolts , brake line bolt and install plastic clips
After all parts are tight put weight on lower control arm and install end links
Measure first end link and make both sides match lengths ( endlink will get smaller the lower you set your ride height)
Check all bolts are tight and instal rims and lower car slowly and check clearance
Rear
Jack up rear of car and put on jack stands
*Tip do not need to remove tire I just did for pics
Remove three bolts
-inside control arm bolt17mm
-endlink 14mm
-shock bolt 17mm
after bolts removed by killer08tc, on Flickr
Remove carpet from trunk (like your removing spare tire )
Fold back carpet with one hand and remove two top nuts with 14mm socket
(Strut will fall right out)
scion frs rear shock bolts top by killer08tc, on Flickr
Reinstall new strut with top nuts
Use jack to lift lower control arm and install three bolts again
Without camber bolts or control arms your rear alignment will get higher amount of camber the lower you go
RWD-boxer is offline   Reply With Quote
Old 11-05-2012, 09:07 PM   #2
RWD-boxer
RWD-boxer's Avatar
Drives: Black
got pics
Bc br coilovers whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 10-20-2012 11:44 PM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 02:45 AM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
D2 coilovers F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2012 03:50 AM
