Old 09-28-2019, 09:34 PM   #113
microsick
Drives: 2017 Toyota 86
Originally Posted by jsimon7777 View Post
My horn wire did pop out, and I didn't align the wheel perfectly. I need to pop everything off, adjust the extender one spline to the right, and then it should be good. Also extend the horn wire.
This might be a REALLY stupid question but how do you extend the horn wire...
I have a 2017 Toyota 86 and actually managed to get the steering wheel buttons to work with the spacer, but the horn wire is just a little too short. Now I have to drive around with no horn which I guess is not THAT MUCH of a big deal but still makes me a little anxious...
microsick is offline   Reply With Quote
Old 09-28-2019, 09:40 PM   #114
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I haven't looked exactly at it, but i think it's just one wire. So get 3" of similarly gauged wired. Trim off insulation on both ends. Cut the current wire. Trim off insulation on both ends. Solder on both ends to extend. Wrap in a bit of electrical tape or shrink tubing. Plug back in.
If it's two wires, repeat all that but with two wires instead of one.
If you don't know how to solder, google it. It's not hard, and I suck at it.
Old 09-28-2019, 09:46 PM   #115
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
or crimp. you can make a jumper to match the ends of the receiver and input
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
EAGLE5 (09-29-2019)
Old 09-29-2019, 07:14 PM   #116
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Originally Posted by iLuveKetchup View Post
An aftermarket seat? hmm.. didn't think of that.
On second thought, I don't think I can swap seats because of class restrictions. But if I did swap seats, is there a solution to the passenger seat sensors? I think it has weight sensors and some other crap??
But you are right, a different seat is the answer (or sell the car). I just wonder how aftermarket seats feel.
Just swap the drivers seat with a better reclining one, no need to swap passenger seat - its more than adequate for a passenger that doesn't need to worry about getting pedal, steering wheel, and shifter in perfect alignment and can brace themselves with feet and hands Expensive enough just doing drivers seat, no need to double it.
Something like this:
Best to find a race shop that is a seat dealer and sit in their seat selection. The FR-S stock seat you sit ON, Recaro Sportster you sit IN and are fully supported... much better feel of what the chassis is doing (instantaneous as well) and padding is much better fit for thigh and butt support, along with no annoying headrest issue.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
EAGLE5 (09-29-2019)
Old 09-29-2019, 09:36 PM   #117
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Non-matching seats? No. Just no.
iLuveKetchup is offline   Reply With Quote
Old 11-05-2019, 03:55 PM   #118
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by 949 Racing View Post
Next batch is 5x the size of the first batch, and should be here around July 15th.
Any plans to make a matching bracket that repositions the signal stalk?
Old 11-05-2019, 04:02 PM   #119
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
None, sorry.
949 Racing is offline   Reply With Quote
The Following User Says Thank You to 949 Racing For This Useful Post:
Yoshoobaroo (11-05-2019)
Old 11-05-2019, 04:07 PM   #120
turbofan
949Racing Support
turbofan's Avatar
Drives: 1999 Mazda Miata Turbo
Typically one becomes very quickly acclimated to the new positioning.
Ed @ 949Racing
949Racing
Supermiata
EMAIL US at info@949racing.com
turbofan is offline   Reply With Quote
Old 11-05-2019, 04:10 PM   #121
Clutch Dog
conversely if you remove the spacer your knuckles hit the stalks unwillingly. XD
its like the throttle spacer.
its not that big of deal after abit
Old 11-05-2019, 04:29 PM   #122
ka-titties
Drives: 2013 BRZ Limited 6MT
https://www.amazon.com/dp/B07MFDRJGH...v_ov_lig_dp_it
ka-titties is offline   Reply With Quote
Old 11-22-2019, 07:58 PM   #123
EAGLE5
Dismember
EAGLE5's Avatar
Would this also work in a Subaru Forester?
Old 11-22-2019, 08:00 PM   #124
949 Racing
949 Racing's Avatar
Untested. Guessing not.
EAGLE5 (11-22-2019)
Old 12-17-2019, 04:38 AM   #125
Hworang
Drives: 2017 BRZ
On newer models with steering wheel controls, the control wiring is not long enough to reach once the adapter is installed and will require an extension harness similar to what is used on other applications. Airbag wiring is fine, so this can still be installed on later models, you will simply lose steering wheel control functionality until the extension harness is available. Extension harness can be installed without removing the steering wheel. No ETA yet for the harnesses, will update when we have more information.
Looking forward to that harness extension! Also just wanted to thank you guys for addressing this issue. Can't wait
Hworang is offline   Reply With Quote
Old 12-17-2019, 01:21 PM   #126
949 Racing
949 Racing's Avatar
We have sourced the necessary connectors in the relatively small quantities needed for our production volume. Working with our harness supplier on quotes, then testing. Guessing early '20 we should have them added to the site. We will update this thread when we have additional info.
Clutch Dog (12-17-2019)
949, spacer, steering
MY2018 GT86 OEM Steering Wheel Spacer AndMsc Cosmetic Modification (Interior/Exterior/Lighting) 7 06-15-2020 09:51 AM
Do spacer's/adapter's cause heavy steering? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2016 10:36 PM
TE37SL Red $2799 - Rays Volk Racing & GramLights, Advan RSII, Eibach Spacer eauto Wheels and Tires 316 10-15-2014 02:41 PM
Steering Wheel Adjustment or Spacer Goya Cosmetic Modification (Interior/Exterior/Lighting) 5 09-29-2014 04:54 AM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 05:33 PM
