Old 08-29-2016, 10:30 PM   #1
lupindub
Drives: Scion FR-S
Do spacer's/adapter's cause heavy steering?
I know a lot of folks on this forum are running 20mm/25mm spacer combo with the stock wheel's and wondering how much heavier the steering feels with this?
I am asking because a couple month's ago I screwed up and got improperly fitting wheel's and adapter (17x8 wheel's with 23mm adapter = 17x8 +20 offset) and noticed how much heavier my steering feels.
Do you think this will demolish my bearings pretty soon or can I keep driving on this setup? I am embarrassed to say this is nearly a $1000 screw up with the wheels and adapters combined together, so reverting back to stock is not so feasible at the moment . I am also running the stock tires (215/45).
lupindub is offline   Reply With Quote
Old 08-29-2016, 11:41 PM   #2
gramicci101
Off Topic
I'm running 20/25mm spacers on OEM wheels and I honestly didn't notice a difference. I've had them on for about two years, with no signs of bearings or steering components wearing out.
The Following User Says Thank You to gramicci101 For This Useful Post:
Teseo (08-30-2016)
Old 08-30-2016, 12:05 AM   #3
PeterFRS
PeterFRS's Avatar
Drives: FRS
yeah.. i dont think i felt any difference with stock wheels and tires with 20mm spacers all around..
mmmaaayyyyy be some when i put on 255.40r17's.. even then..not too bad..
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 08-30-2016, 01:31 PM   #4
8R6
8R6's Avatar
Drives: FRS
what kind of wheels did you get? guessing by the $1000 price tag for 17x8 wheels that are 5x114.3, these are probably some replica wheels that weigh more than the stock wheel setup. if so, the heavy wheels are most likely the reason for the heavier steering feel.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Cole (08-30-2016)
Old 08-30-2016, 02:14 PM   #5
sato
sato's Avatar
Drives: Dodge Patitas
Well, I'm running the stock tire/wheel combo on 20mm/25mm spacers and have begun to feel some "groaning" when making turns at very low speed (i.e. parking lot).
I have been running the spaces for about 35k-40k miles. So I'm not sure if this is an electrical power steering motor noise or bearing noise. I have read that spacers but a bit more load on bearings, but that is something that I might live with.
Not sure if its related, and since I'd have to remove spacers to confirm, it might take a while. Or, I might take a minute to remove them just so we both can have a bit more piece of mind. Will post later on.
Old 08-30-2016, 02:44 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
a general rule:
the lower the offset (from stock), the more stress it puts on the wheel bearings.
over the course of many million miles of ownership across all FRS/BRZ, you will see increased rates of failure if you run lower offset wheels. Whether this happens to you on an individual level or not is entirely luck.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
JazzleSAURUS (08-30-2016), Teseo (08-30-2016)
Old 08-30-2016, 05:07 PM   #7
Cole
Not a troll
Cole's Avatar
This. My wheels are lower offset than stock (+35), wider (17x9) and have a wider tire (245) and I haven't noticed a much heavier steering feeling. But, my wheels with tires are around a pound lighter per side than stock, so that's definitely working in my favour.
The Following 2 Users Say Thank You to Cole For This Useful Post:
8R6 (08-31-2016), tCsonfrs (08-30-2016)
Old 08-30-2016, 06:36 PM   #8
lupindub
Drives: Scion FR-S
They are actually Enkei RP03 and even though they are 17x8, they come in at 17.9 lbs per wheel compared to the 20.1 lbs OEM wheel's....which means I shaved quite a bit of weight, yet having heavy steering.
Is it possible that my wheels/tires are pushed out far enough to cause the heavy steering? I mean 17x8 +20 is quite a bit of poke but the tire treads are completely inside the fender. Only the wheel and part of the sidewall (due to stretched tires) is poking.
The Following User Says Thank You to lupindub For This Useful Post:
8R6 (08-31-2016)
Old 08-30-2016, 06:44 PM   #9
gramicci101
Off Topic
What it does is increase the scrub radius.
So now when you turn the wheel and the car isn't moving, instead of dragging the tire through a small arc around the steering axis, you're dragging it through a large arc. That's more friction it has to overcome, and the power steering has to work harder to do that. If the car is moving then it shouldn't be an issue.
Gunman (08-31-2016)
Old 08-30-2016, 08:15 PM   #10
lupindub
Drives: Scion FR-S
Is it also possible that since my tires are 215 AND +20 offset that the load is both concentrated in a smaller area and pushed out further making the steering heavier?
Compared to your setup where the load is spread out more evenly.
Old 08-30-2016, 08:43 PM   #11
Teseo
Drives: frs
This is legit?
Asking because i want to drop the height with RCE yellows and add wheel spacers on stock wheels
Old 08-30-2016, 09:36 PM   #12
gramicci101
Off Topic
Originally Posted by Teseo View Post
This is legit?
Technically yes. It changes your scrub radius, puts some amount of additional wear on your wheel bearings, etc. So does every single aftermarket wheel and tire setup that isn't 17x7+48 with a 215 tire. People don't hesitate to throw on 17x9+35 with a 255 tire on it, and that does the same thing.
I have RCE yellows and spacers on OEM wheels. It's fine. I've only ever seen wheel bearings fail due to tire choice in the off road world, where people go from a 235/75 to a 44x18.50 and increase the tire weight by about 60 lbs each.
Teseo (08-30-2016)
Works Bell/Splash Steering Wheel Adapter derek1ee Want-To-Buy Requests 1 03-30-2016 11:59 PM
Heavy steering when turning left... Venator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-10-2015 03:07 PM
SOLD! FS: 3/4" PVC Speaker Spacer/Adapter Formula Vee Audio/Visual, Electronics, Infotainment, NAV 3 11-16-2014 02:05 AM
Steering Wheel Adjustment or Spacer Goya Cosmetic Modification (Interior/Exterior/Lighting) 5 09-29-2014 03:54 AM
Steering Wheel Adapter Hub Question Bach415 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2014 05:40 PM
