Old 07-22-2019, 02:11 PM   #99
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by 949 Racing View Post
Ah, few days late. Tracking shows the 23rd. We allowed an extra 10 days as a cushion.. still wasn't enough. Sorry!
No need for sorry. This is to be expected. Thanks for updating! Just put in extra stickers or something. Maybe a free set of wheels.
Old 07-25-2019, 07:59 PM   #100
EAGLE5
Dismember
EAGLE5's Avatar
FYI, received today. It's a good looking set of metal. It's a bit hot and I'm a bit sick, but I hope to get it in next week.
Old 08-05-2019, 02:16 PM   #101
EAGLE5
Dismember
EAGLE5's Avatar
Spacer installed! Should come stock that way.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Clutch Dog (08-05-2019)
Old 08-28-2019, 12:26 PM   #102
turbofan
949Racing Support
turbofan's Avatar
Drives: 1999 Mazda Miata Turbo
On newer models with steering wheel controls, the control wiring is not long enough to reach once the adapter is installed and will require an extension harness similar to what is used on other applications. Airbag wiring is fine, so this can still be installed on later models, you will simply lose steering wheel control functionality until the extension harness is available. Extension harness can be installed without removing the steering wheel. No ETA yet for the harnesses, will update when we have more information.
Ed @ 949Racing
949Racing
Supermiata
EMAIL US at info@949racing.com
turbofan is offline   Reply With Quote
The Following User Says Thank You to turbofan For This Useful Post:
CSG Mike (08-28-2019)
Old 09-17-2019, 03:51 PM   #103
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Thinking of getting this to fix my issue with the OEM seat's headrest angle.
Due to my short arms, I have to set the seat fully erect with the wheel extended to the furthest position. This is fine on the street, but when I have a helmet on, I feel like my head is hunched down and pushed forward by the headrest. I flip the headrest around when autocrossing, which effectively is not having a headrest at all. I roll dice and play the odds of snapping my neck. But at the track, where I go off course, spin, & crash on every lap, I have a higher risk and therefore leave the headrest in the normal position.
Wondering if anyone bought the extension so that they can recline the seat farther back? Logically I think this would solve my problem.
iLuveKetchup is offline   Reply With Quote
The Following User Says Thank You to iLuveKetchup For This Useful Post:
Clutch Dog (09-17-2019)
Old 09-17-2019, 04:59 PM   #104
turbofan
949Racing Support
turbofan's Avatar
Yes, this is exactly the reason for this piece - it allows you to have the wheel closer to you when the rest of the ergonomics are correct.
Ed @ 949Racing
949Racing
Supermiata
Old 09-18-2019, 04:35 PM   #105
supjames
Drives: 2015 Scion FR-S
Hi All,
Just wanted to add that I purchased and installed this extender, and I am impressed. Possibly the greatest upgrade towards driver comfort, I wish I had it sooner! With my install though, I had to extend the horn wire a bit, but air bag wires were left alone.
Also, after first install, the steering wheel was not lining up properly following included directions. I had to go back in and flip the steel piece to where the "this side up" side is down, in order for the splines to line up correctly.
Last edited by supjames; 09-20-2019 at 12:27 PM. Reason: corrected material composition for clarity.
supjames is offline   Reply With Quote
Old 09-18-2019, 05:02 PM   #106
EAGLE5
Dismember
EAGLE5's Avatar
My horn wire did pop out, and I didn't align the wheel perfectly. I need to pop everything off, adjust the extender one spline to the right, and then it should be good. Also extend the horn wire.
Old 09-18-2019, 06:03 PM   #107
turbofan
949Racing Support
turbofan's Avatar
Thanks for the feedback gents. Seems most folks don't have any issues with the horn wire but some do. Also, as mentioned previously, it's a little odd but the "this side up" is etched into the steel piece, but the steel piece is symmetrical - it's the aluminum piece that needs to be oriented a certain way.
They should be assembled correctly out of the box, but you'll need to take care not to invert them since you have to separate the two pieces for installation.
Ed @ 949Racing
949Racing
Supermiata
Old 09-27-2019, 11:42 AM   #108
iLuveKetchup
Drives: EFF JAY
Yup I'm an IDIOT!!! Mad at myself for thinking that I can solve my headrest problem by reclining the seat. ugh!! The spacer works as intended but doesn't fix (nor was intended to) my helmet to headrest problem. In order for the headrest to not push into my helmet, I'd have to recline the seat so much that it would feel like I'm "Rollin in my six-fo".
The spacer itself is a good product. Easy install. Fast shipping too.
Old 09-28-2019, 11:41 AM   #109
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Best solution for that problem is a different seat... will cost $$$$ though. The factory seat was my most disliked thing about my FR-S; stupid headrest and bad ergonomics for me - bought my FR-S knowing I would absolutely be getting rid of the stock seat for one that actually works properly for me. Took me a few years but finally saved up for a seat I know works for me and have been happy since. Find the seat that works for you and stick with it for your vehicles - its your main interface between you and the vehicle and needs to both properly fit to not damage your body over time and to be able to relay all the info it can on what the chassis is doing so you are better tuned in to what the vehicle is actually doing. The stock seat absolutely lacks in supportiveness and the chassis information it can relay.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 09-28-2019, 12:07 PM   #110
iLuveKetchup
Drives: EFF JAY
An aftermarket seat? hmm.. didn't think of that.
On second thought, I don't think I can swap seats because of class restrictions. But if I did swap seats, is there a solution to the passenger seat sensors? I think it has weight sensors and some other crap??
But you are right, a different seat is the answer (or sell the car). I just wonder how aftermarket seats feel.
Old 09-28-2019, 01:44 PM   #111
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Why not just flip the hearest around? Not on the street obviously, but on the track. It make a helmet fit just right.
nico_rsx is offline   Reply With Quote
Old 09-28-2019, 02:02 PM   #112
iLuveKetchup
Drives: EFF JAY
This. I am a very bad driver and crash often. So I need the headrest support.
949, spacer, steering
MY2018 GT86 OEM Steering Wheel Spacer AndMsc Cosmetic Modification (Interior/Exterior/Lighting) 7 06-15-2020 08:51 AM
Do spacer's/adapter's cause heavy steering? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2016 09:36 PM
TE37SL Red $2799 - Rays Volk Racing & GramLights, Advan RSII, Eibach Spacer eauto Wheels and Tires 316 10-15-2014 01:41 PM
Steering Wheel Adjustment or Spacer Goya Cosmetic Modification (Interior/Exterior/Lighting) 5 09-29-2014 03:54 AM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
