Old 03-23-2017, 01:10 PM   #1121
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
I see it drop to 17.5 or so on a hard pull very briefly then goes straight back to 28.4-5 right away. The spurts of boost are shorter and shorter these days.
Originally Posted by fenton View Post
What is it dropping to? If it is 18 or below when you hit the throttle there is a issue with the dump pack connection or dump pack itself. Typically thats what it drops to if it is running off the alternator.
Thanks,
yamsta is offline   Reply With Quote
Old 03-23-2017, 01:12 PM   #1122
fenton
There is something definitely wrong with your dump pack or dump pack connection then. Check that all your fitting are tight and connected. If they are then test the batteries as recommended.
Are you using Odyssey's or powersonic? 2 years is pretty good length for the batteries considering the load we put them under.
Thanks,
fenton is offline   Reply With Quote
Old 03-23-2017, 01:35 PM   #1123
yamsta
daGangsta
yamsta's Avatar
Ok I'll check that this weekend.
I'm running 2x Big Crank ETX16 Batteries for the dump pack. Is there a newer/better battery to run? If so, are the connectors the same?
Thanks.
Thanks,
Old 03-23-2017, 01:35 PM   #1124
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Thanks.
You can use the Odyssey batteries instead of the etx16s if they are bad. And honestly you may like them more.
Installed Mods:
Old 03-23-2017, 03:15 PM   #1125
yamsta
daGangsta
yamsta's Avatar
You have links to the odyssey batteries? Are the connections the same?
Old 03-23-2017, 03:25 PM   #1126
Sojhinn
Sojhinn's Avatar
Yup. PC 680 for the batteries. You may need a new copper bar for the dumps in series.
Installed Mods:
Old 03-23-2017, 03:34 PM   #1127
yamsta
daGangsta
yamsta's Avatar
Oh interesting, thats the battery I'm using as the starter battery. So are people using three of these batteries now? 1 for starter and 2 for dump pack?
Old 03-23-2017, 03:34 PM   #1128
Sojhinn
Sojhinn's Avatar
Yup
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
zc06_kisstherain (03-23-2017)
Old 03-24-2017, 09:03 PM   #1129
stevo585
Drives: White 2014 BRZ
I have 1 PC680 and 2 big cranks only 1 year old 10k miles if anyone interested.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 04-29-2017, 06:22 PM   #1130
Sojhinn
Sojhinn's Avatar
Anyone want these? Pay for shipping and they are yours.
Installed Mods:
Old 05-01-2017, 12:49 AM   #1131
godzuki
godzuki's Avatar
Drives: frs
The voltage will still read 28 volts with a single bad battery. If you are anywhere near San Diego I csn give you one of my extra batteries.
btw, this is exactly the cause of the problem i was having. checked the charge of the dump batteries and one could not keep a charge over 11v. swapped them out for my original power sonic pack until i get my new odysseys in. also invested in a de-sulphering charger. obviously the copper plate between the two batteries was too short, used 10gauge copper electrical wire (single strand) bent to exact fit. works like a charm.
godzuki is offline   Reply With Quote
The Following 2 Users Say Thank You to godzuki For This Useful Post:
DAEMANO (05-01-2017), Sojhinn (05-01-2017)
Old 05-01-2017, 10:11 AM   #1132
yamsta
daGangsta
yamsta's Avatar
Hey guys, I'm selling my car so I'm parting out my ESC and OFT if anyone interested:
http://www.ft86club.com/forums/showthread.php?t=118140
Old 05-02-2017, 01:20 AM   #1133
godzuki
godzuki's Avatar
Drives: frs
watching sojhhin's latest install video (big thx btw) i noticed the dump pack was now grounded (sharing the main battery ground path). can anyone explain the benefit of doing that?
The Following User Says Thank You to godzuki For This Useful Post:
Sojhinn (05-02-2017)
Old 05-02-2017, 01:53 AM   #1134
Sojhinn
Sojhinn's Avatar
Yup. Simpler wiring and Basically the whole car shares the same ground (0 voltage). Less chance for ground loops too.
And no problem!
Installed Mods:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
