Old 01-30-2014, 11:40 AM   #99
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
Originally Posted by milkesfrs View Post
No probs with the ? . I installed the trunk wire from the advance keys to the FRS truck wire in the car with out a trunk switch. If I think I know what your asking. You would need the advanced keys fob to open your trunk by holding the unlock button for 5 seconds. You have to connect a wire from the advance keys to do this fuction.
sorry i think maybe the communication here is still going wonky! haha. i mean like with the limited brz's, they have a physical switch on the trunk that they can use to open the trunk without using their keyfob. similar to the door, the trunk becomes available to open when you're within proximity.
http://www.parts.com/parts/2013/SUBA...agramCallOut=9
Number 9 in that picture is the actual physical switch itself. That's what I'd like to hook up once I do this myself. it'd be one less reason to fumble with the fob!
phanguy is offline   Reply With Quote
Old 01-30-2014, 12:00 PM   #100
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Sorry, no . You have to use the fob.
milkesfrs is offline   Reply With Quote
Old 04-02-2014, 11:40 AM   #101
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Any updates? Drove my brothers g35 with keyless entry and knob style ignition and I'm spoiled.
YamahaR86 is offline   Reply With Quote
Old 04-09-2014, 01:41 AM   #102
Chaetagnath
Drives: Whiteout FRS
It's been done before http://www.ft86club.com/forums/showp...&postcount=101
Chaetagnath is offline   Reply With Quote
Old 03-01-2016, 02:37 AM   #103
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
Hey are you planning on doing that video? I wanna get this kit but don't want to struggle.
I've installed sound systems and even got the nexus 7 in my 86. I remember when my mate bought a easy go kit for his FJ and that looked really complicated to install.
Let all Paypal some cash and get it out there
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
MaXimus is offline   Reply With Quote
Old 11-10-2016, 03:43 PM   #104
dejahboi
dejahboi's Avatar
Drives: 13 FRS - Boosted
Got this installed using one idatalink module. Only issue I'm facing is the remote start function. I hear the unit go on but I don't think its disengaging my clutch switch. As for the push-start function it works great.
dejahboi is offline   Reply With Quote
Old 01-10-2017, 09:37 AM   #105
IronMoose
Drives: 2013 Whiteout FRS
I'm having having an issue with my install. Advanced keys push to start/keyless entry using an idatalink bypass. All functions work but security indicator stays on and doors lock after ignition off. Any suggestions?
IronMoose is offline   Reply With Quote
Old 01-10-2017, 12:07 PM   #106
dejahboi
dejahboi's Avatar
I have that same exact issue lol. I've been lazy to call Brian to help me out with it.
What I'm thinking for the door lock is something is wrong with the polarity. As for the light, I learned to live with it. I haven't found a way to disable it but found fixes to block the light? If that makes sense.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 01-10-2017, 08:32 PM   #107
IronMoose
Im wondering if it has to do with the idatalink firmware. Hopefully someone has answers for us. I'm currently asking around on the Advanced Keys support forums as well. As per blocking the light, I figure you could stick a piece of electrical tape over it behind the cluster overlay.
Old 01-11-2017, 01:59 AM   #108
dejahboi
dejahboi's Avatar
I found that fix somewhere here. Also, are you having a problem with your parking light engaging? I'm having a crappy time turning off my Trac Control, but VSC is not a problem.
Old 01-11-2017, 01:24 PM   #109
IronMoose
No issues with the parking light, however I no longer get an indicator light showing Trac off, though it does disable when VSC is activated
Old 01-11-2017, 10:26 PM   #110
dejahboi
dejahboi's Avatar
Ah, yeah I have a weird problem engaging my Trac off. I'm unsure if its on or off. Also, I meant to say when the parking brake is in engage the parking light indicator is no longer showing. Its finicky to get it to show ( Probably has to do what I did with my parking wire from iData-Link). Instead of me running it to the parking brake signal I grounded it to the chassis (therefore my remote-start doesn't work or I did something wrong with hooking the bosche switch at my clutch and not giving it a proper 12v source) Btw does your remote start work?
Yeah, so if I'm able to get my parking brake signal to work I can disable my "trac off" and it'll display it off on my cluster, otherwise the only thing that works is my VSC.
Old 01-12-2017, 08:31 AM   #111
IronMoose
My remote start works fine but I opted to just ground the neutral safety switch wire.
Old 01-12-2017, 11:18 PM   #112
dejahboi
dejahboi's Avatar
Hmmmm, where did you hook up your 12v wire from the bosche relay connected to the clutch wire? I feel like if I fix that I fix my remote start lol
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 05:20 PM
Advanced Keys for GT owners..? luv85 Australia Classifieds 10 10-22-2013 06:48 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Advanced Keys Inc + Viper 5904 Iddoit2er Electronics | Audio | NAV | Infotainment 5 02-24-2013 02:50 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
