Old 04-27-2016, 07:46 PM   #99
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by Mild2Wild View Post
I'm at 500 already, so there's only one way to go... But I don't use the car for hard launches. Spoke with Weir today and he didn't think the m85 was any stronger than the stock unit; he suggested that I find a 3.73 from the non-locking diff and send it all to him for a refurbish.
Oh, well one thing I can guarantee you is that a m85 is much stronger than the stock BRZ rear. I know guys who have blown up the stock rear end who switched to m85's, and have yet to have problems (all 400+ range).
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 04-18-2017, 12:07 AM   #100
Bobster
Drives: GT86 GTS
Bump! Anyone running Weir performance FD? Are they quiet enough for a daily?
Bobster is offline   Reply With Quote
Old 04-18-2017, 10:00 AM   #101
RichardJ
RichardJ's Avatar
Drives: 15' FRS
I have weir's 4.88 on my AT.
There's an audible whine around 50-70kph while decel.
It is not disturbing and it is quite subtle.
I love the sound tho
RichardJ is offline   Reply With Quote
Old 04-18-2017, 10:48 AM   #102
fika84
fika84's Avatar
Definitely quiet. Most of that depends on who installs it though. I did it myself and can vouch for the need to take it to someone who knows what their doing and takes the time to measure out the bearing preloads and gear contact patch. If preload or contact patch aren't within spec you'll get noise and premature wear.
fika84 is offline   Reply With Quote
Old 04-18-2017, 12:21 PM   #103
jcw99
Drives: swp mt '14 brz premium
my 4.56 is quiet on decel and a bit noisy the rest of the time--there are a number of members who have posted having no noise at any time
jcw99 is offline   Reply With Quote
Old 04-25-2017, 07:45 AM   #104
Bobster
Drives: GT86 GTS
Anyone know whats causing the noise?
Is the M-Factory quieter?
Old 04-26-2017, 02:38 AM   #105
kingkenny
Drives: 2014 Toyota GT86
Pinion clearance need to adjust with proper size shim to minimum the noise , but it is rotation noise you can never get ride of it completely , generally shorter the FD ratio and louder noise .
After a year running the FD , I upgrade the LSD and install Cusco Distance Collar with Nissan shim set and the diff. is much quiet than before .
I notice a few thing when I did these , oem distance collar(Pinion Spacer) can compress a bit by torque it down more less , therefore easier to adjust clearance but the Cusco one is a different case and it simple don't change any when I torque it down . If I do it again , whenever I open the diff. , I would upgrade Pinion spacer again , I suggest anyone doing the FD or LSD should have it .
kingkenny is offline   Reply With Quote
Old 04-26-2017, 03:49 AM   #106
#my86build
I just had my Cusco 4.556 installed a couple of weeks ago. Here are the parts my local shop used in the installation. No new noises to report on mine. That could be the due to fact that it is a Toyota part, it could be the shop that installed it or it could be both. I would also recommend shopping around. I believe FT-86 Speedfactory has theirs marked up $200 USD more than where my shop ordered mine from.
1) Toyota Diff Washer Plate $13 CAD #90201-35518
2) Toyota Diff Case Seal x2 $15.40/per CAD #90311-38070
3) Toyota Diff Shims x2 $18.92/per CAD #90564-46043
#my86build is offline   Reply With Quote
Old 04-28-2017, 08:10 AM   #107
jefri91
Drives: Pearl White
So it's a nice sound? Not something like that'll give you a heart attack everytime you gear?
Got an auto and thinking of also doing the weir's 4.88. How are you liking yours?
Sent from my HTC 10 using Tapatalk
jefri91 is offline   Reply With Quote
Old 04-28-2017, 10:17 AM   #108
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I've got a Weir 4.56. It can get noisy. Shop (@PTuning) spent a considerable amount of time to get it as perfect as possible. Its louder than OEM because of the type of cut in the gear, and its thicker/stronger than OEM.
I'll get a recording later today if you're interested.
SpectreRT is offline   Reply With Quote
The Following User Says Thank You to SpectreRT For This Useful Post:
Teseo (04-28-2017)
Old 04-28-2017, 11:37 AM   #109
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Yea it's personally a pleasant sound lol. Nothing too bad I think.
Driving around town is improved with more wheel torque. When I full throttle in 1st gear I have slight wheel spin with 245's all around.
Old 04-28-2017, 12:05 PM   #110
Icecreamtruk
Drives: Track preped NA FRS
Weir 4.88 also has a small sound to it. 18 months of street driving and 13 track days (2h to 3h of track time per track day) tells me that the sound is normal, since oil doesnt come out with metal pieces and the sound hasnt changed at all during this time.
Old 04-28-2017, 12:09 PM   #111
Teseo
Drives: frs
As long dont fall apart, im ok with sound/noise.
Video will be helpfull if you have time for make it
Old 04-28-2017, 01:46 PM   #112
fika84
fika84's Avatar
The type of cut is the same as OEM. Look at them side by side, exact same cut, different number of teeth to create different ratio.
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 489 06-17-2018 12:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 08:38 PM
