Old 11-19-2015, 09:21 PM   #99
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Chad86 View Post
I've decided to stick with 0W20 running an oil cooler until my free oil changes are over. Then I will look at running 10W40 or 5W30. @CSG_Mike said I should be fine with an oil cooler.
http://www.ft86club.com/forums/showthread.php?t=94293
i was being sarcastic. i dont know which oil is best for these applications. i used toyota's 0w20 when pushing 220, and switched to motuls 5w30 when i raised the power to 255. winters coming, so i dont know if i should switch to an 0w20 or stick to the 5w30
Astroboy is offline   Reply With Quote
Old 11-20-2015, 11:06 AM   #100
Jonde875
Drives: GT86
I have same problem!
I use now Castrol Edge Professional 0W-30 C3 but dont know should I change that to 0W-20 Toyota XS....
Jonde875 is offline   Reply With Quote
Old 02-03-2016, 12:58 AM   #101
NOTORIOUS.BRZ
Drives: SUBARU BRZ ZN6 AU 2013
Would castrol edge 5w30 fully synthetic titanium a3/a4 be compatible for a turbo build brz ?
NOTORIOUS.BRZ is offline   Reply With Quote
Old 02-04-2016, 11:07 AM   #102
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Genuine Oil from Subaru directly isn't expensive. Just keep changing your oil every 3750 miles "6035 Km" max and you'll be fine. The blow-by I'm getting is crazy
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-15-2016, 01:43 PM   #103
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Got my oil report back. Ill be sticking with Amsoil 5-30 on this engine. I dont know about going 10k miles with track season coming up, but I like what I am seeing. No idea where the silicone content came from.
xkalelx is offline   Reply With Quote
Best oil for turbo engine whitefrs Forced Induction 36 10-09-2014 02:45 PM
Engine Noise on Turbo FRS whitefrs Forced Induction 23 04-18-2013 10:30 AM
1.6L DI TURBO ENGINE quik1987 BRZ First-Gen (2012+) — General Topics 39 11-30-2011 06:01 PM
FT-86 / FR-S engine will be Toyota 2l turbo!! Slide Engine, Exhaust, Transmission 114 07-07-2011 11:58 PM
Do you want a turbo engine for the FT-86? Read here Ramo BRZ First-Gen (2012+) — General Topics 86 06-23-2011 09:39 PM
