Old 05-28-2013, 07:23 PM   #99
s2d4
s2d4's Avatar
Because this isn't my first time to see a cut open filter after E85 use
Are you saying E85 will not eat the glues, seals and lines on a vehicle designed for up to E10 only?
s2d4 is offline
Old 05-28-2013, 07:24 PM   #100
Visconti
Drives: 05 STi
Originally Posted by JerryMichaels7 View Post
so John and Don why do you think his did that and don's car shows no sign of anything? I am weary now cuz i was about to get the e85 n/a tune next check.
His sending unit is dirty because of dirty fuel..
Why his filter is having a issue? most likley from some additive he put in his car.
Ethanol doesn't do things like that !
John
Ethanol does NOT eat glue
Visconti is offline
Old 05-28-2013, 07:29 PM   #101
s2d4
s2d4's Avatar
What kind of chemical composition is the glue you are referring to?
s2d4 is offline
Old 05-28-2013, 07:32 PM   #102
SkullWorks
Drives: SSM LT MT BRZ
John
Plenty of ASSumptions in there, We know you have an ego and a bottom line to protect but get over yourself you don't get to choose what Ethanol does and doesn't do because it suits products you sell.
Glue...big subject...wouldn't use overwhelming statements about what does and doesn't eat glue...(did you eat glue as a kid john???)
I use Ethanol to clean adhesive (glue) off stuff all the time at work...
So where did you get the "info" about his fuel quality and additives?
SkullWorks is offline
Old 05-28-2013, 07:35 PM   #103
Visconti
Drives: 05 STi
The fuel filters that are in this car seem to be the same as the ones in the current generation STI, WRX, Forester etc, which have no problems.
Ethanol will eat anything alcohol based.. so if your glue is alcohol based.. you'll have a problem
And as I stated before, I looked into this before offering ethanol calibrations.
I'm sorry if the data Don posted busted what Robispec has shared.
Visconti is offline
Old 05-28-2013, 07:36 PM   #104
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
lol @SkullWorks
SmsAlSuwaidi is offline
Old 05-28-2013, 07:42 PM   #105
robispec
Drives: Black frs project
Man i wish my filter looked as good as yours we took our system apart because it started missing above 6k rpm and was getting worse. We replaced allvthe park potential issurs no changes
So we started in on the fuel system we have run over 500 gallons through our car and found the problem my scion friends were having with there cars...
Originally Posted by Don@Accelerated View Post
So what exactly had you prematurely cutting the filter open. Maybe I missed the initial problem.
For the sake of argument I went and cut my factory filter housing up. I have 4k+ only E85 Miles basically. I have no signs of any degredation to the filter. Now it is true that over time the paper gasket will now allow heavy enough flow for the E85. I haven't run into that scenario yet. It can't be a sitting issue either because mine sat the entire winter here. I wasn't able to put many miles on it.
Have you been/or ever have used an octane booster in the car? Fuel Supplement Additive? It looks crystaline in that picture. E85 is not going to cause that.
I have pictures of my filter and it looks nothing like yours, and doesn't show the slightest sign of any issues yet. My car sat all winter with
Lets discuss further
robispec is offline
Old 05-28-2013, 07:45 PM   #106
SkullWorks
SEEMS the same...go to market , cool motto
Or a whole list of other adhesives that aren't alcohol based...yes your statement is true but it is also deceiving, a glue doesn't have to be alcohol based to be broken down in the presence of alcohol.
As comforting as that is...it isn't, I know you didn't pull the hose and subject it to months of submersion tests or even bother to look up the SAE required testing for E-85 compatibility of fuel components...so lets not act like you did,
We simply have 2 data points, I have been running E-85 for months (on the AEM standalone you insist doesn't work) and had no issue so, believe me I would much rather E-85 be a non-issue than a huge issue, but im not ignorant enough to put the problem on a shelf because one filter looks good and one looks like shit.
Robi also fills up in California...It may be an issue with the cali blend gas only? it may be a flow increase issue, (though Don's car has seen higher specific flow I assume)
There is always a potential for manufacturer defects or changes in supplier of the filter...lots of possibilities.
Old 05-28-2013, 07:51 PM   #107
Visconti
Drives: 05 STi
Anything is possible, but not the first time I've looked at a filter inside the gas tank on a BRZ / FRS / GT86
So again, I'm not concerned
I'd be more concerned with running that AEM lol
-John
Visconti is offline
Old 05-28-2013, 07:52 PM   #108
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Aren't we looking at a single instance of failure in a car that has had the absolute shit beat out of it? (high flow E-85, boosted, 8k track use,5k on E-85, and i saw mention of lucas fuel injector cleaner)... This is worst case scenario stuff here. Not saying that @robispec doesn't take care of his ride as he does so in ways i could only dream of.
Now, if all of the current E-85 users suddenly jump on board and start posting pics of their disintegrated filters then i would hit the panic button. For all we know, one of Robi's buds pissed in the tank after a long night of a Krystals and a bag of cheetos chased down with Everclear.:happy0180:
Just saying it's only a single instance and it seems we are jumping to conclusions before all of the variables are even defined let alone understood...
pixel67 is offline
The Following User Says Thank You to pixel67 For This Useful Post:
CBR600RR (05-28-2013)
Old 05-28-2013, 07:53 PM   #109
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
for now im going to lay off of e85 until further notice but this was last video I took of me doing an e85 pull. going to miss it
this is with spare tire removed, back seats removed, and all tools removed from the trunk...going up hill a little in the begging and then leveled out towards the end. 0-60 in 5.8 and 1/8mile in 9.0 secs @80.5mph according to torque app
[ame="http://www.youtube.com/watch?v=5gwRKjowrRc&list=UUHe66qjLawxdL8lELNUvXKA& index=1"]Scion FR-S e85 0-90 run - YouTube[/ame]
brichard0625 is offline
Old 05-28-2013, 08:07 PM   #110
s2d4
s2d4's Avatar
@Visconti
Feel free to answer this question.
s2d4 is offline
Old 05-28-2013, 08:09 PM   #111
SkullWorks
-John
If I were you I'd be concerned too...it takes a real tuner to make it work...
Old 05-28-2013, 08:12 PM   #112
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Did my Master's degree on flex fuel control systems. Sorry fellows... it's pretty unlikely that there's a conspiracy afoot.
Between 1990-1993, most companies were already developing systems that were safe to run ethanol. By the OBDII refresh (MY1996), most manufacturers had already spec'ed the tanks, lines, filters, injectors to withstand ethanol. Some manufacturers designed for slow wear (just enough to support E10), but most chose materials that did not (in any reasonable time period) degrade in E100.
The fueling control systems were still archaic, since closed-loop fueling was just reaching the stage of using HEGO switching to keep the catalyst cycling (oxidation and reduction at ~1 Hz). These type of systems would fall back to fail-safe maps and waste a ton of fuel. Around MY2000, most manufacturers moved to UEGO based systems which allowed you to generate adaptive A/F ratio targets. It took a few years for these to get implemented, but most had multiple maps pre-programmed. I was reading about Subaru strategies a few years ago, and they use Map "A" and "B" which could be switched between based on feedback about current and expected performance (generally centered around knock and exhaust temps). Regardless, the systems were capable of storing and flowing E85 for the entirity of the car's life. Ethanol eats alot of modern materials... but they currently use materials that dissolve VERY slowly (if at all).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline
The Following 15 Users Say Thank You to Shankenstein For This Useful Post:
2forme (05-29-2013), Apoc (05-28-2013), Calum (05-28-2013), cobrabyte (05-29-2013), guarapo (05-28-2013), JiB (05-28-2013), King Tut (05-29-2013), P&L Motorsports (05-29-2013), RavioliG (08-07-2014), robispec (05-29-2013), Slick (06-04-2013), Sportsguy83 (05-29-2013), Visconti (05-28-2013), Xero-Limit (05-28-2013), xjohnx (05-28-2013)
drama, e85, santa loses it
Bluetooth fix for Android/Samsung users inimitable Electronics | Audio | NAV | Infotainment 27 05-10-2013 06:52 AM
Marginally good use for BeSpoke users! Mandy Electronics | Audio | NAV | Infotainment 12 02-15-2013 09:07 AM
E-85 users thread Crossover Auto Engine, Exhaust, Transmission 41 11-16-2012 07:21 PM
Warning light came on, what could it be? whtchocla7e Issues | Warranty | Recalls / TSB 13 10-21-2012 04:20 PM
Rwd toyota users here? aphxero Other Vehicles & General Automotive Discussions 14 12-23-2009 09:34 PM
