go_a_way1
Old 10-30-2014, 03:41 PM   #1093
CSG David
CSG David's Avatar
Originally Posted by *LongFella View Post
Thanks!
I'm actually leaning towards a full Tomei set-up. Keep it light and the same brand.
Tomei EL Header + Tomei OP + Tomei test pipe + 60S
It will be loud, but I want the performance now. I'm done with doing a "look" thing... LOL!
That will be loud, but let us know when you're ready.
For this engine, this car, and particular setup, the CBE doesn't make a whole lot of difference in performance, but is definitely used to accent the exhaust note and maximize weight savings.
On another note, the Tomei products seem to be very efficient...
Originally Posted by ScionOfHorus View Post
I dunno, I thought I'd read that somewhere before in this thread.
Axleback and catback exhausts don't require a retune. Custom tune is required only if you modify the cat in the header AND/OR cat in the front pipe. On top of that, you will probably need a MAP sensor as well to go with a hybrid or speed density tune.
The Following User Says Thank You to CSG David For This Useful Post:
ScionOfHorus (10-30-2014)
Old 10-31-2014, 03:05 PM   #1094
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I love coffee.
The only thing love more than my FRS is my Keurig!
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
CSG Mike (10-31-2014)
Old 10-31-2014, 03:25 PM   #1095
I've been cold brewing with a dual filter french press lately
JDKane527 (10-31-2014), Scottemad123 (10-31-2014)
Old 10-31-2014, 04:18 PM   #1096
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Aren't you Mr Fancy Pants ;-)
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 10-31-2014, 04:48 PM   #1097
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Stove-top is the way to go! It uses an injector!
alpax is offline   Reply With Quote
Old 10-31-2014, 05:38 PM   #1098
Lunatic
Lunatic's Avatar
How bout an IV?
Old 11-01-2014, 01:25 AM   #1099
Ikea french press with a paper coffee filter. Not very fancy.
Old 11-01-2014, 05:32 PM   #1100
*LongFella
*LongFella's Avatar
Jackson Racing Supercharger Owners Thread
Guys I need some help...
My oil cooler kit is still seeping oil between the plates. This is the second time I've tried to fix it.
Can someone tell me how the rubber seals are suppose to be placed in the extension plate and the thermostatic valve???
Originally, the flat side of the rubber o-ring was exposed. The other side is not flat and almost seems like it should be the side making the seal... It came with the flat side exposed though...
Size:  129.1 KBName:  ImageUploadedByTapatalk1414873940.698843.jpg
Size:  242.9 KBName:  ImageUploadedByTapatalk1414873948.916225.jpg
Size:  133.0 KBName:  ImageUploadedByTapatalk1414873956.515880.jpg
Old 11-01-2014, 06:29 PM   #1101
*LongFella
*LongFella's Avatar
Read, re-read, and triple read the instructions...
No good pics of how the o-rings are suppose to sit...
Come on fellow owners... help a bro help!!!
Old 11-01-2014, 07:15 PM   #1102
Ridged side out!
Old 11-01-2014, 07:19 PM   #1103
*LongFella
*LongFella's Avatar
Ridged side out!
Just reinstalled and nothing's leaking. Thank god!
They came with the flat side of the o-ring facing out and there's nothing in the instruction showing that stuff was wrong. I didn't even think the o-rings came out until I was trying to figure this sh@$ out...
Maybe an update to the instructions are in order??
Old 11-02-2014, 02:54 PM   #1104
*LongFella
*LongFella's Avatar
Yup... Spoke to soon...
Leaks still there...
After looking at everything again, I'm thinking the o-ring seal on the thermostatic plate is defective. I read about some Perrin Oil Cooler owners with the same issue.
I'm hoping Jackson Racing can help out...
Old 11-02-2014, 03:26 PM   #1105
*LongFella
*LongFella's Avatar
Question:
If I disconnect the oil cooler kit and run the car without, should I worry about oil starvation or too much oil?
Dip stick isn't the most accurate...
Old 11-02-2014, 04:55 PM   #1106
*LongFella
*LongFella's Avatar
^This
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
