Old 10-29-2014, 11:20 PM   #1079
enivid
enivid's Avatar
Drives: WRB JR BRZED
Originally Posted by JerseyMike View Post
I created a group on Facebook called FT86 Jackson Racing SC owners.
Why is it mostly populated with non-owners? Kick them out.
enivid is offline   Reply With Quote
Old 10-30-2014, 12:35 AM   #1080
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Man I spent way too long deciding on turbo vs SC, and then deciding which kit I wanted, but I finally ordered mine earlier today. Can't wait!
Thanks for all the info in this thread. The JRSC kit really seems like the best one for a DD.
campy is offline   Reply With Quote
Old 10-30-2014, 02:54 AM   #1081
DaiTT500
DaiTT500's Avatar
Drives:
Just installed mines tonight! Waiting to button all things up tomorrow. Name:  ImageUploadedByTapatalk1414652056.894533.jpg
DaiTT500 is offline   Reply With Quote
Old 10-30-2014, 07:05 AM   #1082
CSG Mike
CSG Mike's Avatar
Originally Posted by DaiTT500 View Post
Just installed mines tonight! Waiting to button all things up tomorrow. Attachment 94709
You might want to lower the angle of the air filter slightly so that it's roughly parallel with the charge pipe. This will prevent it from touching the hood
Old 10-30-2014, 07:50 AM   #1083
JerseyMike
I just added whoever joined, I'll have to go through it later.
JerseyMike is offline   Reply With Quote
Old 10-30-2014, 08:03 AM   #1084
DaiTT500
DaiTT500's Avatar
Drives:
Thanks for the tip Mike! I really appreciate it.
Old 10-30-2014, 11:31 AM   #1085
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
@CSG Mike
I remenber chat about a CBE not doing much performance-wise... With that being said, will there be any issues with my JR Kit and CARB Tune if I put my stock CBE back on?
I want to go a different route on my exhaust and plan to sell my Perrin 2.5" (non-resonsated) CBE.
Thanks!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 10-30-2014, 11:36 AM   #1086
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by *LongFella View Post
@CSG Mike
Thanks!
The CARB tune was developed on the stock exhaust. You will be fine.
JDMChris is offline   Reply With Quote
Old 10-30-2014, 11:36 AM   #1087
*LongFella
*LongFella's Avatar
I figured, but wanted to check with the experts! Thanks!
Old 10-30-2014, 01:21 PM   #1088
CSG David
CSG David's Avatar
Catback exhaust (mid pipe and axleback) and overpipe/joint pipe are fine to change. Do not, I repeat, do not modify the primary AND secondary catalytic converters on the CARB tune. In otherwords, your standard CBE exhausts that you see all over the place, those are fine to use.
On another note, we installed a MXP dual exhaust on a client's car and the fitment was so modular and easy to work with that it's definitely something people should look into. Sound quality is quite good too!
Old 10-30-2014, 01:23 PM   #1089
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Wait, I though axelback needed a retune? And only cat back was fine on the carb tune?
ScionOfHorus is offline   Reply With Quote
Old 10-30-2014, 01:28 PM   #1090
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Why would a catback be ok but not an axleback?
Old 10-30-2014, 01:29 PM   #1091
*LongFella
*LongFella's Avatar
Thanks!
I'm actually leaning towards a full Tomei set-up. Keep it light and the same brand.
Tomei EL Header + Tomei OP + Tomei test pipe + 60S
It will be loud, but I want the performance now. I'm done with doing a "look" thing... LOL!
Old 10-30-2014, 01:51 PM   #1092
ScionOfHorus
I dunno, I thought I'd read that somewhere before in this thread.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
