Old 05-18-2014, 02:02 AM   #1037
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Are you still on the stock header?
Freeman is offline   Reply With Quote
Old 05-18-2014, 02:28 AM   #1038
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Yes
digital_assassin is offline   Reply With Quote
Old 05-18-2014, 05:02 AM   #1039
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Originally Posted by glamcem View Post
yesterday, I did my first lapping event with Kraftwerks and all I can say is wow, I have to re-learn to drive this car again since the shifting points and gear selection for the certain turns are completely changed
I also took some logs and my oil temps were about the same (260-265 F) with last time but I have to add the ambient temps were higher yesterday (highest was around 220F) but I noticed it recovers a lot quicker ( both oil and coolant temps) maybe I should combine my oil to air with an air to air , coolant temps were a bit higher and I think I might have left some air in the system when changing the radiator I will make sure there is no air left..
Now you're making me think I may not want to install my OEM Forester oil cooler parts I had previously ordered. Has anybody confirm fitment (or non-fitment) of the Mocal thermostatic plate with Kraftwerks kit?
mit_peid is offline   Reply With Quote
Old 05-18-2014, 06:13 AM   #1040
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
nope, I would still recommend using the OEM Forester oil cooler , as I mentioned, the ambient temps were considerably higher yesterday when compared to my previous event...55 F vs 75 F, and on top of that, I was running a Supercharger kit which should definitely increase the overall temps yet I was still able to see the same oil temps with the addition of KW ..I think the issue was; I wasn't able to burp the coolant system when changing my OEM radiator with KoyoRad and since the oil temps (with OEM unit ) depends on the Radiator coolant temps (since it's an oil to water ) by reducing Coolant Temps, I should be able to reduce Oil temps .. Many people who switched to FI don't really see any increase in coolant temps and also many people don't even bother upgrading the radiator ..and since my coolant temps were higher yesterday even with a bigger radiator, that was the first thing that came on my mind..
I will make sure there is no air in the system and report back
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
mit_peid (05-18-2014)
Old 05-18-2014, 12:51 PM   #1041
digital_assassin
I have the KW oil cooler installed and I added a Derale remote thermostat. It works beautifully.
The Following 4 Users Say Thank You to digital_assassin For This Useful Post:
Freeman (05-18-2014), glamcem (05-18-2014), mit_peid (05-18-2014), OICU812 (05-19-2014)
Old 05-18-2014, 01:51 PM   #1042
NCItaly
Drives: 2013 BRZ Limited
Just bought a used kit. Does anyone have a link to install instructions or maybe even a video? I can't seem to find anywhere. ..
NCItaly is offline   Reply With Quote
Old 05-18-2014, 01:57 PM   #1043
SPCorBUST
SPCorBUST's Avatar
I don't know if they're online, but there was a paper packet that came with the kit.
Sent from my SGH-M919 using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 05-18-2014, 02:00 PM   #1044
NCItaly
Haha well I guess I should have found that out sooner
Old 05-18-2014, 02:29 PM   #1045
digital_assassin
I have the instructions linked on the first post in this thread. I suggest you read the first couple pages of this thread
Old 05-18-2014, 02:37 PM   #1046
Model Citizen
Lacking brains
Drives: frz
Not in america we don't read things first.
Go back to finland.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
Old 05-18-2014, 03:10 PM   #1047
glamcem
glamcem's Avatar
What were your coolant temps looking like? Was there a significant delta before/after the oil cooler? (we have existing data that shows that just adding a Rotrex supercharger doesn't significantly affect coolant temps on track).
*edit*
I just got around to watching your video. Do you normally shift early, even before the SC? Engine RPM has a direct correlation to oil temperature that is fairly independent of actual engine output.
Mike, previously I have seen 205F-210F with OEM radiator and after the bigger radiator and KW I saw a few 230F as my coolant temps. Since as in his recent post @Model Citizen and you've just mentioned that the coolant temps were not affected with the Rotrex I think it's just my mistake when installing the KoyoRad I couldn't do a good job getting rid of the air in the system.
Normally, I always shift when I see the blip I believe it's set to 7400 rpm from factory ( I haven't changed it) but maybe in my videos it's not visible or I might have shifted a bit early
Old 05-18-2014, 03:19 PM   #1048
Model Citizen
Lacking brains
Drives: frz
think you misread my post, or i wrote it wrong,
kw kit has been on since january or so, got the scanguage about a month ago, my comparison was of pre cooler post cooler, both with sc.
my bad if i wrote it like shit.
on the upside, the little oe sandwich cooler absolutely helps, just probably not to a technically adequate degree.
The Following 2 Users Say Thank You to Model Citizen For This Useful Post:
CSG Mike (05-19-2014), glamcem (05-18-2014)
Old 05-18-2014, 11:19 PM   #1049
NCItaly
Oh my bad, Must've looked right passed it
Old 05-19-2014, 12:57 AM   #1050
I'll clarify as well. The Rotrex does put more heat into the stock cooling system, but not so much that it can't handle it. In other words, the peak temps were the same.
However, (this is where the clarification comes in), the rate of fluctuation in the temperatures is now faster. The fans turn off at about 185F, and turn back on at about 195F (depends on which temp sensor you're logging). Once the fans turn on, coolant temps start to go down, and when they turn off, the temps start to go back up. The rate at which the temps goes back up was faster post-Rotrex, indicating that there was indeed more heat going into the coolant, but the fans were able to bring the temps down every time, also indicating that the stock system is more than capable of handling that extra horsepower.
When you start dumping oil heat into the radiator... well, my data set for that is not yet large enough to draw any conclusions.
glamcem (05-19-2014)
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
