#1038 |
Drives: 2013 FR-S Matte Orange
Yes
#1039 | |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Now you're making me think I may not want to install my OEM Forester oil cooler parts I had previously ordered. Has anybody confirm fitment (or non-fitment) of the Mocal thermostatic plate with Kraftwerks kit? |
#1040 | |
Drives: 2022 BRZ Limited
, as I mentioned, the ambient temps were considerably higher yesterday when compared to my previous event...55 F vs 75 F, and on top of that, I was running a Supercharger kit which should definitely increase the overall temps yet I was still able to see the same oil temps with the addition of KW ..I think the issue was; I wasn't able to burp the coolant system when changing my OEM radiator with KoyoRad and since the oil temps (with OEM unit ) depends on the Radiator coolant temps (since it's an oil to water ) by reducing Coolant Temps, I should be able to reduce Oil temps .. Many people who switched to FI don't really see any increase in coolant temps and also many people don't even bother upgrading the radiator ..and since my coolant temps were higher yesterday even with a bigger radiator, that was the first thing that came on my mind..I will make sure there is no air in the system and report back
| The Following User Says Thank You to glamcem For This Useful Post: | mit_peid (05-18-2014) |
#1041 | |
I have the KW oil cooler installed and I added a Derale remote thermostat. It works beautifully.
#1042 |
Drives: 2013 BRZ Limited
Just bought a used kit. Does anyone have a link to install instructions or maybe even a video? I can't seem to find anywhere. ..
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
#1043 | |
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#1044 |
#1045 | |
I have the instructions linked on the first post in this thread. I suggest you read the first couple pages of this thread
#1046 | |
Lacking brains
Drives: frz
Go back to finland. |
| The Following User Says Thank You to Model Citizen For This Useful Post: | glamcem (05-18-2014) |
#1047 | |
Normally, I always shift when I see the blip I believe it's set to 7400 rpm from factory ( I haven't changed it) but maybe in my videos it's not visible or I might have shifted a bit early
#1048 | |
Lacking brains
Drives: frz
kw kit has been on since january or so, got the scanguage about a month ago, my comparison was of pre cooler post cooler, both with sc. my bad if i wrote it like shit. on the upside, the little oe sandwich cooler absolutely helps, just probably not to a technically adequate degree. |
#1049 |
#1050 | ||
I'll clarify as well. The Rotrex does put more heat into the stock cooling system, but not so much that it can't handle it. In other words, the peak temps were the same. However, (this is where the clarification comes in), the rate of fluctuation in the temperatures is now faster. The fans turn off at about 185F, and turn back on at about 195F (depends on which temp sensor you're logging). Once the fans turn on, coolant temps start to go down, and when they turn off, the temps start to go back up. The rate at which the temps goes back up was faster post-Rotrex, indicating that there was indeed more heat going into the coolant, but the fans were able to bring the temps down every time, also indicating that the stock system is more than capable of handling that extra horsepower. When you start dumping oil heat into the radiator... well, my data set for that is not yet large enough to draw any conclusions. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | glamcem (05-19-2014) |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
