#1009 | |
![]() http://www.ft86club.com/forums/showthread.php?t=86521
#1010 |
Drives: 2013 Scion FRS
Ehhh hahaha. Not quite but Thanks man
ScreamingElectron - SnakeShit |
#1011 |
Speed density functionallity is not in the standard ecu code just like fc\ffs is a code patch written by someone and applied to the original ecu code.
the only person who has done it is ztan in the post linked above. You would need to get the software patches applied to your rom. your only going to need that over about 10psi boost else you can stick with the stock ecu code and maf based fueling |
#1012 | |
make sure you have both sensors plugged in make syre black plug to black socket, grey plug to grey socket. the two o2 sensors are different check rge 02 heater fuse if shop did not run thread tap\chaser through o2 bungs in header and they had to force sensor in they may have damaged sensor or both sensor |
#1013 | |
Drives: 2013 GBS BRZ
#1014 |
#1015 |
So what are my options in tuning a kraftwerks charger?
#1016 |
I think only ecutek. If you haven't purchased the kit yet, you can use OFT with a Vortech kit.
#1017 |
Whats a good template to use to tune it with oft?
#1018 |
I think Shiv has one on his website, but that might only be available if you buy the blower from him
#1019 |
as above if you buy the oft vortech sc kit you get tune to suit think its about 9psi on petrol, it not a base tune its full working tune
http://openflashtablet.com/Automotiv...300/index.html |
#1020 |
You think it would work on a different kit?
#1021 |
Drives: Asphalt 2014 FRS
#1022 |
Drives: UK GT86
Doesn't the KW require SD due to the MAF housing? If so, you need an SD patch for your ROM for OS tunes or ECUtek, there is no other way. If you cannot tune via the MAF then no ported tunes would work. The Vortech tune would probably run, but you'd not be able to go WOT.
.: Stealth 86 :.
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
