Old 12-13-2015, 09:00 PM   #1009
D_Thissen
D_Thissen's Avatar
Originally Posted by riboyster View Post
Anyone got any info on Speed Density tables and such? I'm really trying to avoid EcuTek when I get my blower. Might dabble in that and get a working tune, but need some tables and info to start.
Maybe in here? I don't know what I'm looking for.
http://www.ft86club.com/forums/showthread.php?t=86521
Old 12-13-2015, 09:20 PM   #1010
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Ehhh hahaha. Not quite but Thanks man
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 12-13-2015, 09:32 PM   #1011
steve99
Drives: FT86
Speed density functionallity is not in the standard ecu code just like fc\ffs is a code patch written by someone and applied to the original ecu code.
the only person who has done it is ztan in the post linked above. You would need to get the software patches applied to your rom.
your only going to need that over about 10psi boost else you can stick with the stock ecu code and maf based fueling
Old 12-13-2015, 09:38 PM   #1012
steve99
Drives: FT86
Originally Posted by xiayu0320 View Post
Same issue with Borla uel header. Still getting p0031 code after clear.
Poo31 is o2 sensor heater circuit
make sure you have both sensors plugged in
make syre black plug to black socket, grey plug to grey socket.
the two o2 sensors are different
check rge 02 heater fuse
if shop did not run thread tap\chaser through o2 bungs in header and they had to force sensor in they may have damaged sensor or both sensor
Old 12-13-2015, 09:55 PM   #1013
xiayu0320
Drives: 2013 GBS BRZ
Thanks man! I'll check it again.
xiayu0320 is offline   Reply With Quote
Old 12-13-2015, 10:06 PM   #1014
steve99
Drives: FT86
so car starts now ? problem was battery ?
Old 12-13-2015, 10:12 PM   #1015
riboyster
riboyster's Avatar
So what are my options in tuning a kraftwerks charger?
Old 12-13-2015, 10:18 PM   #1016
D_Thissen
D_Thissen's Avatar
I think only ecutek. If you haven't purchased the kit yet, you can use OFT with a Vortech kit.
Old 12-13-2015, 10:20 PM   #1017
riboyster
riboyster's Avatar
Whats a good template to use to tune it with oft?
Old 12-13-2015, 10:28 PM   #1018
D_Thissen
D_Thissen's Avatar
I think Shiv has one on his website, but that might only be available if you buy the blower from him
Old 12-13-2015, 10:37 PM   #1019
steve99
Drives: FT86
as above if you buy the oft vortech sc kit you get tune to suit think its about 9psi on petrol, it not a base tune its full working tune
http://openflashtablet.com/Automotiv...300/index.html
Old 12-13-2015, 10:43 PM   #1020
riboyster
riboyster's Avatar
You think it would work on a different kit?
Old 12-14-2015, 02:28 AM   #1021
austin_ellas
Drives: Asphalt 2014 FRS
I would not recommend trying.
austin_ellas is offline   Reply With Quote
Old 12-14-2015, 03:55 AM   #1022
Kodename47
Kodename47's Avatar
Drives: UK GT86
Doesn't the KW require SD due to the MAF housing? If so, you need an SD patch for your ROM for OS tunes or ECUtek, there is no other way. If you cannot tune via the MAF then no ported tunes would work. The Vortech tune would probably run, but you'd not be able to go WOT.
.: Stealth 86 :.
Kodename 47 DJ:
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
