#1009 | |
Drives: 86 GT MT
Excellent, I look forward to the update. Can oil temp be added as a third display? Also can an option be added for Metric measurements including degrees Celcius for temps? |
#1010 | |
#1011 |
In ecutek:
Fueling -> Air/Fuel Correction -> AF Correction #3 Limit - Rear O2 Sensor
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | steve99 (04-10-2014) |
#1012 |
Drives: FR-S 10 #103 AT
Finding E85 is a bit of a PITA around here, but I just have to try it once to see what all the fuss is about. I'm sure this was covered somewhere, but again, too many threads/posts to read them all.
So my questions are: "how low do you have to run the tank of 93 before refilling with E85 and reflashing?" and "is it the same level when going back to 93?" That last seems like an obvious "yes" but I've learned to take nothing for granted.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#1013 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
I have switched just a few times, but I always run it down as low as possible. I usually get 11.5 gallons in when I switch and I drive for several miles before flashing. If the trims are fluctuating too much after flashing (like 51 miles), I will usually flash again to the new map under the assumption that the first flash was too early and the trims were compensating for the 93.
| The Following User Says Thank You to Luckrider For This Useful Post: | mid_life_crisis (04-10-2014) |
#1014 | |
#1015 | |
#1016 | |
Drives: 86 GT MT
I was looking for this info myself. See http://www.ft86club.com/forums/showp...32&postcount=1 After changing to E85, I idled the car for a couple mins, then drove low revs and slowly for about 5 mins. The second tank E85 feels slightly better. |
| The Following User Says Thank You to keen as For This Useful Post: | mid_life_crisis (04-10-2014) |
#1017 |
OFM 1.07.1 datalog problems
@shiv@vishnu
Just connected OFT to laptop it did upgrade. also upgraded OFM to 1.07.1 version connected again and let it update. Firmware in OFT 1.26. also update template again no joy. Tried to read new datalog and get unhandled exeption error Bug ?? or am I doing something wrong See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentException: Source array was not long enough. Check srcIndex and length, and the array's lower bounds. at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length, Boolean reliable) at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length) at PWGDATALOGGING.PWGDataLogging.readSignals(Byte[] Src, List`1& Signals) at PWGDATALOGGING.PWGDataLogging.getFileFromDevices(B yte[] DataFile, DataSet& Values) at PWGPro.DataLoggingForm.readRtime(String NomeFile) at PWGPro.DataLoggingForm.buttonReadDevice_Click(Obje ct sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3655 (GDR.050727-3600) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- PWGPro Assembly Version: 1.7.1.0 Win32 Version: 1.7.1.0 CodeBase: file:///C:/OpenFlash/OpenFlash%20Manager.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3645 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3644 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3644 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- CommonResources Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/CommonResources.DLL ---------------------------------------- PWGResources Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/PWGResources.DLL ---------------------------------------- PWGCommand Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/PWGCommand.DLL ---------------------------------------- PWGService Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/PWGService.DLL ---------------------------------------- System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3654 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3654 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- r7bmnqxt Assembly Version: 1.0.0.0 Win32 Version: 2.0.50727.3644 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- HidLibrary Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/HidLibrary.DLL ---------------------------------------- System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.1 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Windows.Forms.Ribbon35 Assembly Version: 3.5.7.0 Win32 Version: 3.5.7.0 CodeBase: file:///C:/OpenFlash/System.Windows.Forms.Ribbon35.DLL ---------------------------------------- PWGPro.resources Assembly Version: 1.7.1.0 Win32 Version: 1.7.1.0 CodeBase: file:///C:/OpenFlash/en-US/PWGPro.resources.DLL ---------------------------------------- System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3645 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll ---------------------------------------- PWGResources.resources Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/en-US/PWGResources.resources.DLL ---------------------------------------- PWGCommand.resources Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/en-US/PWGCommand.resources.DLL ---------------------------------------- PWGService.resources Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/OpenFlash/en-US/PWGService.resources.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. |
#1018 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
EDIT - added to all roms on Github Last edited by Td-d; 04-11-2014 at 12:01 PM. |
#1019 | |
I'm having the exact same issues on two different PC's. I contacted them and am hoping for a quick solution as well. |
#1020 | |
Drives: 2014 Scion FR-S
Sent from my SM-N900T using Tapatalk |
#1021 | |
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#1022 | |
Yeah, I thought this might be it, but this morning I made sure I stopped the log before turning the car off or disconnecting the OFT. Same result. |
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 04:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 04:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 09:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 12:53 PM |
