Old 04-10-2014, 12:38 AM   #1009
keen as
keen as's Avatar
Drives: 86 GT MT
Originally Posted by shiv@vishnu View Post
Yep! That will come later. The colorful bar graph on the bottom would actually display AFR while the numberical value would show boost.
Excellent, I look forward to the update.
Can oil temp be added as a third display?
Also can an option be added for Metric measurements including degrees Celcius for temps?
keen as is offline   Reply With Quote
Old 04-10-2014, 12:51 AM   #1010
steve99
Drives: FT86
Originally Posted by nelsmar View Post
Yes on ecutek we can use it as an input. However in factory form there is a fuel trim compensation for rear o2. I have a local who has a problem and is getting DTC's that I have resolved by setting these values to 0 from -0.5 / 0.5 (factory values). The oem ecu uses these values to apply minor fuel trims. I never tested to what extent it will trim through, its a bit of a PITA to test something like that!
Where did you find those tables ?
Old 04-10-2014, 10:35 AM   #1011
nelsmar
In ecutek:
Fueling -> Air/Fuel Correction -> AF Correction #3 Limit - Rear O2 Sensor
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
steve99 (04-10-2014)
Old 04-10-2014, 11:47 AM   #1012
mid_life_crisis
Drives: FR-S 10 #103 AT
Finding E85 is a bit of a PITA around here, but I just have to try it once to see what all the fuss is about. I'm sure this was covered somewhere, but again, too many threads/posts to read them all.
So my questions are: "how low do you have to run the tank of 93 before refilling with E85 and reflashing?" and "is it the same level when going back to 93?"
That last seems like an obvious "yes" but I've learned to take nothing for granted.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-10-2014, 12:30 PM   #1013
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I have switched just a few times, but I always run it down as low as possible. I usually get 11.5 gallons in when I switch and I drive for several miles before flashing. If the trims are fluctuating too much after flashing (like 51 miles), I will usually flash again to the new map under the assumption that the first flash was too early and the trims were compensating for the 93.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
mid_life_crisis (04-10-2014)
Old 04-10-2014, 01:18 PM   #1014
mid_life_crisis
I had to think about this for a second until I realized I had overlooked the fuel already in the line. I hadn't even considered logging, which I now realize was short sighted. It sounds like a whole can of worms I should avoid for a one time thing. Especially since if I like it that much, I'll be screwed because corn juice is not readily available in these parts.
Old 04-10-2014, 02:32 PM   #1015
Luckrider
Luckrider's Avatar
Hell No... I did it for just one tank of e85 and it wasn't bad at all. It might not have been optimal, but that is how you make sure everything is good.
Old 04-10-2014, 07:26 PM   #1016
keen as
keen as's Avatar
Drives: 86 GT MT
I was looking for this info myself. See http://www.ft86club.com/forums/showp...32&postcount=1
After changing to E85, I idled the car for a couple mins, then drove low revs and slowly for about 5 mins.
The second tank E85 feels slightly better.
The Following User Says Thank You to keen as For This Useful Post:
Old 04-11-2014, 01:29 AM   #1017
steve99
Drives: FT86
OFM 1.07.1 datalog problems
@shiv@vishnu
Just connected OFT to laptop it did upgrade. also upgraded OFM to 1.07.1 version connected again and let it update. Firmware in OFT 1.26.
also update template again no joy.
Tried to read new datalog and get unhandled exeption error
Bug ?? or am I doing something wrong
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length, Boolean reliable)
at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length)
at PWGDATALOGGING.PWGDataLogging.readSignals(Byte[] Src, List`1& Signals)
at PWGDATALOGGING.PWGDataLogging.getFileFromDevices(B yte[] DataFile, DataSet& Values)
at PWGPro.DataLoggingForm.readRtime(String NomeFile)
at PWGPro.DataLoggingForm.buttonReadDevice_Click(Obje ct sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3655 (GDR.050727-3600)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
PWGPro
Assembly Version: 1.7.1.0
Win32 Version: 1.7.1.0
CodeBase: file:///C:/OpenFlash/OpenFlash%20Manager.exe
Win32 Version: 2.0.50727.3645 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.3644 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CommonResources
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/OpenFlash/CommonResources.DLL
PWGResources
CodeBase: file:///C:/OpenFlash/PWGResources.DLL
PWGCommand
CodeBase: file:///C:/OpenFlash/PWGCommand.DLL
PWGService
CodeBase: file:///C:/OpenFlash/PWGService.DLL
System.Web.Services
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
Win32 Version: 2.0.50727.3654 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
r7bmnqxt
HidLibrary
CodeBase: file:///C:/OpenFlash/HidLibrary.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.1 built by: SP
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Windows.Forms.Ribbon35
Assembly Version: 3.5.7.0
Win32 Version: 3.5.7.0
CodeBase: file:///C:/OpenFlash/System.Windows.Forms.Ribbon35.DLL
PWGPro.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGPro.resources.DLL
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
PWGResources.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGResources.resources.DLL
PWGCommand.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGCommand.resources.DLL
PWGService.resources
CodeBase: file:///C:/OpenFlash/en-US/PWGService.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Old 04-11-2014, 09:52 AM   #1018
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
In ecutek:
I've added AF 3 correction, learning and rear o2 comps to the ZA1JA01C definition up on Github. I'll add to the other definitions shortly.
EDIT - added to all roms on Github
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
s2d4 (04-11-2014), steve99 (04-11-2014)
Old 04-11-2014, 10:37 AM   #1019
R2
@shiv@vishnu
I'm having the exact same issues on two different PC's. I contacted them and am hoping for a quick solution as well.
R2 is offline   Reply With Quote
Old 04-11-2014, 10:55 AM   #1020
DC2R
Drives: 2014 Scion FR-S
Name sure you manually stop the logging. Had same issue when I just unplugged tablet and forgot to stop logging first.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 04-11-2014, 11:01 AM   #1021
phrosty
@shiv@vishnu
Was the log recorded prior to the update? Looks like the data log record size has changed. Wonder if this brings any new goodies.
phrosty is offline   Reply With Quote
Old 04-11-2014, 11:22 AM   #1022
R2
Yeah, I thought this might be it, but this morning I made sure I stopped the log before turning the car off or disconnecting the OFT. Same result.
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
