Old 06-02-2016, 04:19 PM   #967
stevo585
Drives: White 2014 BRZ
Anyone have Rob's email? My voltmeter failed awhile back and its now annoying me.
I also think my controller is overheating. Seems to not response well on hot days.
Thanks!
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 06-02-2016, 05:21 PM   #968
PantsDants
Drives: Scion FR-S A/T, Whiteout
@Sojhinn @l0aded
I'm on the PowerSonic batteries still, going to upgrade to three PC680s soon. What all do I need to get in terms of install parts so that I have everything when the batteries arrive? Sounds like I need a longer copper dump connector (can't you just use some heavy gauge wire for that?). Does the old plastic top cover not sufficiently protect the connections on the new batteries?
Thanks guys.
PantsDants is offline   Reply With Quote
Old 06-03-2016, 12:53 AM   #969
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Thanks!
PMed.
Did you pull out the stereo jack and it failed or did it randomly just shut off? Are you sure it is the voltmeter and not the fuse connection or the stereo wire?
l0aded is offline   Reply With Quote
Old 06-03-2016, 01:25 AM   #970
l0aded
Addicted
l0aded's Avatar
Originally Posted by PantsDants View Post
@Sojhinn @l0aded
Thanks guys.
Not sure what your cables/barriers look like since I started on the ETX16s but here is a pic of mine with the provided barrier sitting ontop. Since I don't have 3x PC680s yet, I couldn't use the barrier as my ETX16 starter battery terminals are facing right which made it not sit with the holder/terminal wood block ontop.
I think with 3x PC680s it would sit fine though.
For connecting the two batteries together I am sure thick gauge wire would be fine if you could secure it. Personally I think using a copper bar would be cleaner and simpler. You can purchase a bar from McMaster-carr with approximate dimensions of 6" long x 0.5" wide x 1/8" thick ($2.45 + ship), cut off the excess length you don't need, and drill two holes for the bolts to go through and you're good to go.
http://www.mcmaster.com/#8964K4
The Following 2 Users Say Thank You to l0aded For This Useful Post:
PantsDants (06-03-2016), Sojhinn (06-03-2016)
Old 06-03-2016, 01:28 AM   #971
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
What he said.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
l0aded (06-03-2016), PantsDants (06-03-2016)
Old 06-03-2016, 02:17 AM   #972
l0aded
Addicted
l0aded's Avatar
BTW what motor oil are you guys running? I've been on Eneos Sustina 0w-20 for the last 2 rounds but it is kinda pricey. Also I never track but do push my car hard on the streets.
Thinking about going back to TGMO which is half the price but not sure how running a supercharger means for the quality of oil I need.
Old 06-03-2016, 08:57 AM   #973
Sojhinn
Sojhinn's Avatar
I'm running mobil 1 synthetic. I just change it sooner.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
l0aded (06-08-2016)
Old 06-03-2016, 09:40 AM   #974
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Mobile 1 here too
I usually change it between 5K - 7K
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
l0aded (06-08-2016)
Old 06-03-2016, 02:34 PM   #975
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Mobile 1 for me also. I change every 6 months (~2,000 mi)
The Following User Says Thank You to Target70 For This Useful Post:
l0aded (06-08-2016)
Old 06-03-2016, 09:18 PM   #976
stevo585
PMed.
Mines a V1 kit...used. There is no stereo jack. But yes the voltmeter just randomly died. I heard it was common. I use the 12v charger port in the glove box as a switch. Once I get the torque app up and I'm able to log boost ill know more. As it seems to feel almost NA at times when its 90 F out. Maybe just the heat soak but I am on e85.
Old 06-03-2016, 09:33 PM   #977
Sojhinn
Sojhinn's Avatar
Yeah it was fairly common for the v1s for the volt meter to pop.
Installed Mods:
Old 06-14-2016, 03:42 PM   #978
super josh
Drives: Mazda mx5
I replaced my voltmeter for an amber coloured one (to match the dash colour in my mx5) and just measured the dimensions and bought a generic 30V one off the bay.
Josh
super josh is offline   Reply With Quote
Old 06-14-2016, 11:00 PM   #979
stevo585
Josh
Does it have a switch in it? Those seem hard to find. I've seen lots of basic 30V ones.
Do you have a site link?
Thanks
Old 06-15-2016, 01:42 PM   #980
super josh
Drives: Mazda mx5
Thanks
Not sure what you mean by a switch as that is connected to the case of my dash mounted voltmeter. All I replaced was the voltmeter pcd itself which needs to be soldered in to the circuit.
Something like this one Clicky
A lot on ebay are 3 wire, so make sure you get a 2 wire one.
Josh
The Following User Says Thank You to super josh For This Useful Post:
stevo585 (06-16-2016)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
