03-20-2013, 01:54 AM | #967 | |
Drives: Whiteout FR-S
http://www.ft86club.com/forums/showt...ighlight=advan |
03-20-2013, 09:45 AM | #968 | |
AutoX-10/10ths every run
@JoeBoxer and I talked a bunch about wheels for my car before I bought them. His advice is good.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | JoeBoxer (03-20-2013) |
03-20-2013, 11:01 AM | #969 |
If you're cheap like me, go with 8" wheels because of the option of running 225/45/17.
There's also some thought that 225 on 8" will post better laptimes at stock hp (CSG Mike), and in theory you will retain more steering feel vs. 245 on 9".
2022 BRZ Build 2013 FR-S Build |
03-20-2013, 11:04 AM | #970 |
Member of Junior
Drives: 2013 Subaru BRZ
I checked out the wheel fitment calculator. I'm looking at 17x8 with +42 offset. It looks awefully close. Anyone have any real world experience with this size?
03-20-2013, 11:13 AM | #971 | |
This is a good option too, it's weird that most people with 17's have 9" width and most 18's are 8" width. I guess thats just what's available there are very few 18x9's out there and they would be getting up there in weight also. |
03-20-2013, 11:54 AM | #972 | |
Drives: FR-S Firestorm 6MT
You should be pretty safe in that size unless planning a huge tire. Lots of guys are running 17x9 +45 with 245 wide tires (some 255's) and although close to the strut, "it clears". |
03-20-2013, 11:57 AM | #973 |
Close is right... this is 18x8.5 +45 front, with a 245/35. I reached inside the rim, pointing straight up for this view.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm.. |
03-21-2013, 03:03 AM | #974 |
Grip>Drift
Drives: FRS
I've been running 17x9 et42 245/40/17 since about 1000 miles on the car. I'm at 24K miles now.
03-21-2013, 11:31 AM | #975 |
Drives: B9 S4/ND2
17x9. you can still run a 225 on that, and the weight increase on the RPF1 is negligible.
03-21-2013, 04:11 PM | #976 |
Hot Lava 6MT
Drives: Hot Lava FR-S
Offset Tires
Would I be fine to run 225/35/19 in the front and 245/45/19 in the rear?
Aside from the obvious sidewall height differences, is there any other concern that I should be made aware of with offset tire sizes? |
03-21-2013, 04:34 PM | #977 |
If the diameter is too different, the VSC/TC systems might think one end is slipping, and under braking it could think one end is locking up slightly.
Why wouldn't you run 225/45 up front and 245/35 out back? 245/45/19 is WAY bigger than stock, to the point where it will look quite stupid. Stock tires are 24.7" tall, 245/45/19 is 27.7" tall. 225/40/19 is 26.1" tall and 255/35/19 is 26" tall. Both are quite a bit taller than stock, but are closer to each other and won't cause issues from being too differently sized. *edit* - Just saw the title, I think you mean staggered, not offset.
03-21-2013, 04:44 PM | #978 |
Drives: B9 S4/ND2
the tires are way too tall and might not even fit in the rear. The car will be slow as shit as well because you're reducing the gearing by 12% with those tall tires.
My question is why are you even considering those sizes? Edit: I should reply more quickly, WParson was a bit more eloquent |
03-21-2013, 05:02 PM | #979 |
Hot Lava 6MT
The reason I am considering the tires is that I already have 4 of them. However it appears that I may be better off trying to sell them and get something a bit smaller.
03-22-2013, 07:05 PM | #980 |
Smokin on Dat Endo
Tire sizing on my new wheels
Need help !!! Im on stock suspension.
Want to run 18x8.5 +38 in the front and 18 x 9.5 + 38 in the rear! Want to run a square tire setup with no stretching for a daily driver
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
