#85 | |
Drives: Hydra EMS Powered FRS Raven Black
We can make the current Ferrea fit however. |
#86 |
Drives: '15 BRZ RA
#87 |
Drives: Moped
All the dips who kept saying the 2013 motors were the same as the 2014/15/16 have sure become quiet the last few months...lol
#88 | |
Drives: Toyota 86 GTS
Most of the power loss on later cars isn't due to different parts, it's because they change parts without updated calibration. Most later cars I've seen lose power because they run super rich on the stock tune compared to the original cars and/or they have more variance than the early cars that had more consistency. Here's a stock MY15 AT hitting 10.0 AFR at 6500rpm. It doesn't stand a chance compared to a stock car that runs at 12 and hits 11.0-11.5 up top. It will make exactly the same power as an early car when the MAF scale has been corrected to be in the same ballpark as an early MY car though. |
#89 |
Drives: Toyota GT86 Satin-White-Pearl
That's exactly what i mentioned. A quite severe powerloss throughout the powerband.
Misfires and rough running when cold and hard to go over 133mph. When i realized that i have to tune the new car again loosing my guarantee i was quite disappointed, because my old 2012 was buggy as hell but running fine on stock tune. What hardware modifications can be done to correct that unpleasent state without touching software? MAF spacer? By the way some RPM fluctuation occured too but that was only some sort of "calibration" after resetting the ecu and gone after a thousand miles or so. A MY2015 is a much better car in terms in safety and quality but that thing is again a severe fail by Subaru not matching the calibration. What about emissions? Is that fat running engine better or worse? The new ones should be better on the emissions side, but hopefully not by cutting power. |
#90 |
Drives: GTS 86
#91 |
Much less oversteering for safety and simply no rattles outside and inside the car.
What the fuck am i talking about? Very many issues based on build quality and i felt that i had them all. You're a 2012 member so you should know.
#92 |
Drives: GTS 86
I have a 2012 and very little issues really. No rattles though...I must've been lucky enough to get a good one.
#93 |
Drives: '15 BRZ RA
A few respectable aftermarket companies consider already the 2015-16 engines as a different kid in the town. Some examples below:
Too bad we don't have yet a definite answer from the factory about the actual changes. Only some sporadic information here and there. |
#94 | |
Drives: 2013 Asphalt FRS
No valve changes since 2014 2013 thru 2015 short block is the same 10103AC260 As you can see no real changes in 2015. Probably Toyota needs a new part number for filing system who knows My 2012-13 motor ran 13.47 N/A no problems 35K on it. My 2014 motor made 640hp so in my opinion the year doesn't really effect anything, it's just a FA20
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 02-12-2016 at 04:27 AM. |
#95 |
Drives: '15 BRZ RA
What is your reference? Some website? By the way, good luck with your 640hp engine ...
Only safe reference is the Subaru EPC application which comes from the factory. This is what dealers use. In fact there were some more engine changes in the 2016 models. What we know about the changes is that they were made for safety. These engines are supposed to withstand (in stock form) for many years and factory doesn't want to have a bad reputation with many broken ones. |
#96 |
Senior Misanthrope
#97 |
Drives: '15 BRZ RA
It's not only about legal requirements, but I don't want to start here a meaningless discussion.
#98 | |
So in closing I will leave you with these thoughts, 1: Why 4 years later did these Safety changes happen instead of sooner this engine is still a boxer nothing new. 2 Wouldn't you think they would have worried about their reputation long before now on this new platform? 3: If 2015 is so special why are they exploding too? EDIT: Looks like their are no "safety changes" in the short block since 2012
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 02-12-2016 at 02:12 PM. |
| Anyone have specs on differences btw 2014 and 2015 FR-S | jeepmor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-25-2014 04:54 AM |
| Two reviews of the 2015 up - handling differences noted | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 08-13-2014 01:22 PM |
| The 2015 STI use 2.0T Engine for Nurburing 24H | Whitigir | Other Vehicles & General Automotive Discussions | 6 | 03-18-2014 04:22 PM |
| Can anyone confirm the engine in a 2015 Subaru WRX? | Figo | Other Vehicles & General Automotive Discussions | 28 | 01-01-2014 11:43 AM |
| FR-S vs. BRZ Differences - Engine/Model Codes | Flipside909 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 05-07-2012 02:26 PM |
