Old 07-20-2015, 11:37 PM   #85
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by celek View Post
Have you been kind enough to notify Ferrera and any other valve manufacture of the changes in the valves? I would assume you were building a customer head and discovered the differences ordering valves that no longer fit.
I mentioned the tip length to Ferrari eons ago. They acted like I didn't know what I was talking about and told me to press in new valve seats. LOL! They want too much money for custom valves so I've started working with someone else.
We can make the current Ferrea fit however.
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
celek (07-21-2015)
Old 10-11-2015, 02:25 AM   #86
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Some more information here:
http://www.ft86club.com/forums/showp...&postcount=642
The Following User Says Thank You to nikitopo For This Useful Post:
Lonewolf (10-11-2015)
Old 10-11-2015, 07:52 PM   #87
Lonewolf
Lonewolf's Avatar
Drives: Moped
All the dips who kept saying the 2013 motors were the same as the 2014/15/16 have sure become quiet the last few months...lol
The Following User Says Thank You to Lonewolf For This Useful Post:
FRS Justin (10-12-2015)
Old 10-11-2015, 10:09 PM   #88
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by sw20kosh View Post
Advice for 2015 owners: don't dyno your car at 2000 miles...
155 whp 128 wtq on a dynojet where 2013 and 2014's dyno at 165-172 whp
Most of the power loss on later cars isn't due to different parts, it's because they change parts without updated calibration. Most later cars I've seen lose power because they run super rich on the stock tune compared to the original cars and/or they have more variance than the early cars that had more consistency.
Here's a stock MY15 AT hitting 10.0 AFR at 6500rpm. It doesn't stand a chance compared to a stock car that runs at 12 and hits 11.0-11.5 up top.
It will make exactly the same power as an early car when the MAF scale has been corrected to be in the same ballpark as an early MY car though.
Old 10-12-2015, 01:42 AM   #89
Hector
Drives: Toyota GT86 Satin-White-Pearl
That's exactly what i mentioned. A quite severe powerloss throughout the powerband.
Misfires and rough running when cold and hard to go over 133mph.
When i realized that i have to tune the new car again loosing my guarantee i was quite disappointed, because my old 2012 was buggy as hell but running fine on stock tune.
What hardware modifications can be done to correct that unpleasent state without touching software? MAF spacer? By the way some RPM fluctuation occured too but that was only some sort of "calibration" after resetting the ecu and gone after a thousand miles or so. A MY2015 is a much better car in terms in safety and quality but that thing is again a severe fail by Subaru not matching the calibration. What about emissions? Is that fat running engine better or worse? The new ones should be better on the emissions side, but hopefully not by cutting power.
Hector is offline   Reply With Quote
Old 10-12-2015, 02:12 AM   #90
Hawk77FT
Drives: GTS 86
Originally Posted by Hector View Post
A MY2015 is a much better car in terms in safety and quality .
How would it be better in terms in safety and quality than the MY2012 for instance?
Hawk77FT is offline   Reply With Quote
Old 10-13-2015, 01:25 AM   #91
Hector
Much less oversteering for safety and simply no rattles outside and inside the car.
What the fuck am i talking about? Very many issues based on build quality and i felt that i had them all. You're a 2012 member so you should know.
The Following User Says Thank You to Hector For This Useful Post:
Hawk77FT (10-13-2015)
Old 10-13-2015, 02:52 AM   #92
Hawk77FT
Drives: GTS 86
I have a 2012 and very little issues really. No rattles though...I must've been lucky enough to get a good one.
Old 12-13-2015, 04:13 AM   #93
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A few respectable aftermarket companies consider already the 2015-16 engines as a different kid in the town. Some examples below:
Too bad we don't have yet a definite answer from the factory about the actual changes. Only some sporadic information here and there.
The Following 4 Users Say Thank You to nikitopo For This Useful Post:
Bonburner (02-12-2016), Hostile_Kittens (12-13-2015), Lonewolf (12-14-2015), Trap63 (12-13-2015)
Old 02-12-2016, 02:50 AM   #94
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by nikitopo View Post
I did the check for Subaru. However, the part numbers also changed for Toyota. Following are some examples:
Valve, Intake
old SU003-00196
new SU003-04745
Valve, Exhaust
old SU003-00197
new SU003-04746
Camshaft, Intake, RH
old SU003-00180
new SU003-04741
Camshaft, Exhaust, RH
old SU003-00181
new SU003-04742
Head & Valve Set, Cylinder, RH
old SU003-00103
new SU003-04958
Since the car is a Subaru I will use Subaru part #'s
No valve changes since 2014
2013 thru 2015 short block is the same 10103AC260
As you can see no real changes in 2015. Probably Toyota needs a new part number for filing system who knows
My 2012-13 motor ran 13.47 N/A no problems 35K on it. My 2014 motor made 640hp so in my opinion the year doesn't really effect anything, it's just a FA20
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 3 Users Say Thank You to FRS Justin For This Useful Post:
Apoc (02-12-2016), Bonburner (02-12-2016), chaoskaze (02-12-2016)
Old 02-12-2016, 12:01 PM   #95
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
What is your reference? Some website? By the way, good luck with your 640hp engine ...
Only safe reference is the Subaru EPC application which comes from the factory. This is what dealers use. In fact there were some more engine changes in the 2016 models. What we know about the changes is that they were made for safety. These engines are supposed to withstand (in stock form) for many years and factory doesn't want to have a bad reputation with many broken ones.
Old 02-12-2016, 12:28 PM   #96
kch
Senior Misanthrope
kch's Avatar
His motor is fully built & sleeved, so it's legit.
The Following User Says Thank You to kch For This Useful Post:
FRS Justin (02-12-2016)
Old 02-12-2016, 12:44 PM   #97
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It's not only about legal requirements, but I don't want to start here a meaningless discussion.
Old 02-12-2016, 01:55 PM   #98
FRS Justin
You won't be the first I have to educate.....The pictures posted were the electronic parts catalog. I didn't see the need to post 6 more pages to prove the short block is the same number, or to prove anything else I posted. Do you think I make this stuff up? No I research, and I develop, and I help anyone who asks. It's quite obvious you don't know me or what I've done and that is ok, but before you start questioning what I have done bring something to the table besides you wishful thinking and wrong information. 2016 made safety changes??? What the hell is that???? Why don't you sit down and bring up 3 windows of the EPC and start finding the differences like I did?
So in closing I will leave you with these thoughts,
1: Why 4 years later did these Safety changes happen instead of sooner this engine is still a boxer nothing new.
2 Wouldn't you think they would have worried about their reputation long before now on this new platform?
3: If 2015 is so special why are they exploding too?
EDIT:
Looks like their are no "safety changes" in the short block since 2012
710whp
Anyone have specs on differences btw 2014 and 2015 FR-S jeepmor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-25-2014 04:54 AM
Two reviews of the 2015 up - handling differences noted Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 56 08-13-2014 01:22 PM
The 2015 STI use 2.0T Engine for Nurburing 24H Whitigir Other Vehicles & General Automotive Discussions 6 03-18-2014 04:22 PM
Can anyone confirm the engine in a 2015 Subaru WRX? Figo Other Vehicles & General Automotive Discussions 28 01-01-2014 11:43 AM
FR-S vs. BRZ Differences - Engine/Model Codes Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 5 05-07-2012 02:26 PM
