go_a_way1
Old 03-30-2015, 02:09 PM   #85
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Originally Posted by NotEric6 View Post
I had no idea you had access to such machines! Very cool sir. That's the issue we're running into with him testing. They've been running the machines 24/7, he can't even get it on the test stand on Sundays sometimes.
Regarding mechanical shock testing, it's typically done with a pneumatic/hydraulic system like this:
It builds pressure then pushes the parts up in one-shot. High force (40 - 200G) and short duration (5 - 20 ms).
For milder shock testing where you're not going to have fixture or parts resonance... you can use a shaker table (this one is using a slip table).
Doing a control arm would be complicated. You'd need to fix both 2 of 3 pivot points and apply the shock load on the third (just like with the Instron testing above).
It's probably cheaper to just throw it on a race car and beat on it.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline
The Following User Says Thank You to Shankenstein For This Useful Post:
CSG Mike (03-30-2015)
Old 03-30-2015, 02:18 PM   #86
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Wouldn't be cheaper if you crashed because of the product...lol
cdrazic93 is offline
Old 03-30-2015, 02:39 PM   #87
Shankenstein
Frosty Carrot
For Mike's situation, you may have luck finding a giant pendulum (like the charpy or izod) impact tester.
Many universities and labs will have these, and it's an easy way to wang on stuff in a controlled manner.
Old 03-30-2015, 03:28 PM   #88
Xuningshen
Drives: Subaru BRZ
The structural designer in me loves the truss look of your design. makes me feel better compared to the other ones.
Originally Posted by eric6 View Post
Figured it about time to update the thread . So we started development with a few overall goals and then capitalized on them with extensive FEA analysis. FEA (Finite Element Analysis) uses a numerical, computer based technique to solve complex scenarios. A variety of scenarios can be predicted, such as stress, heat transfer, vibration, fatique, and other physical effects. The power of FEA lies in the ability to solve problems that would be extremely difficult or impossible to solve by hand. Similar to CFD, FEA partitions the structure into a finite number of elements. These elements form standard shapes, such as triangles, quadrilaterals, hexagons, etc. The use of these standard shapes allows the development of a governing equations that can related stresses and displacement within the element. Please keep in mind that FEA is a tool, and in the wrong hands, it can be like shooting a target blindfolded. You need accurate inputs for an accurate output. .........
Please let us know if you have any questions. We will be testing these units off car soon, which should let us know how well our FEA analysis lines up with real world results. Then... onto some race cars .
2014 WRB BRZ
Xuningshen is offline
Old 03-30-2015, 08:21 PM   #89
That's exactly what I had in mind.
CSG Mike is offline
Old 04-01-2015, 07:39 PM   #90
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Talking
This is how WE do shock testing. (To be clear, this is not my video, but my product has been through this test at this facility.)
[ame="https://www.youtube.com/watch?v=x_a-XjdGV_s"]MIL-STD-901D shock test, 20 feet - YouTube[/ame]
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline
Old 04-02-2015, 01:10 AM   #91
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by NissanGuy View Post
These aluminum arms are meant to be lighter than SPL's titanium? If so, props.
Titanium's denser than aluminum, plus has a worse stiffness to weight.
Aluminum, especially the aerospace grades, can outperform titanium in certain aplications.
Between 6061 and 7075... 2024?
Because titanium.
Dimman is offline
Old 04-02-2015, 01:56 AM   #92
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
SPLs only use titanium for the lock nut and the bolt on their clamp I believe. The LCA itself is 6061-T6.
I'm away on business for my day job. I will write up our findings when I return home on Saturday.
VerusEric is offline
The Following User Says Thank You to VerusEric For This Useful Post:
Dimman (04-02-2015)
Old 04-04-2015, 04:48 PM   #93
VerusEric
VerusEric's Avatar
Alright so after Sunday's test, we found out that the adjuster fails prematurely when cyclically loaded. We believe we actually instigated the failure slightly by heating up the unit by loading it at 10 Hz (friction/movement builds heat). Regardless, we don't believe it would have reached our goal of 50,000 cycles. It did last fairly long though and in most cases, the unit wouldn't have failed in our opinion. It would have still lasted multiple seasons but not long enough for us to take it to production.
We have already machined up replacement adjusters and ordered high strength alloy rod ends. This will add about 0.2 lbs per LCA, however, we have effectively increased the strength of these two pieces by 75%. Realistically, we don't need to re-test, but we want to.
On top of that, we are going to test the OEM unit and see how it fairs in the same tests we are testing our LCA in. The person who is testing said he can probably get it on the bench next weekend.
Thanks for your patience,
Eric
The Following 7 Users Say Thank You to VerusEric For This Useful Post:
2much (04-04-2015), Black Tire (04-05-2015), civicdrivr (04-08-2015), D_Thissen (04-04-2015), Jonsey (04-04-2015), MINOCIN (04-07-2015), Shankenstein (04-04-2015)
Old 04-04-2015, 09:39 PM   #94
Calum
That Guy
Drives: 2013 asphalt FRS MT
Eric
Pics or it didn't happen!! I want to see those results, please.
Calum is offline
Old 04-04-2015, 11:22 PM   #95
Shankenstein
Frosty Carrot
Eric
FMEA squad up!
Even when threads are "helped" with a glass bead blast, hardening, or heat treatment... there's always stress concentration due to shape. Many times, you've got residual stresses too.
Fatigue testing will find the weak point and initiate a crack. At this point, the crack is its own stress concentration. The material's toughness dictates how much concentration... and it's just a matter of cycles before the part is #rekt.
Thanks for posting the news publicly. There is no failure in R&D... we follow the cycle:
test --> anomaly --> problem definition --> root cause --> corrective action --> re-test
It's only a failure once you've put it in the field, and it seems like you guys are going the extra mile to ensure customer satisfaction.
The Following 3 Users Say Thank You to Shankenstein For This Useful Post:
200hp/tonne (04-27-2016), plucas (04-05-2015), VerusEric (04-05-2015)
Old 04-05-2015, 01:18 AM   #96
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
and it seems like you guys are going the extra 1.62 kilometers to ensure customer satisfaction.
Fixed.
Captain Snooze is offline
Calum (04-05-2015)
Old 04-05-2015, 09:58 AM   #97
Shankenstein
Frosty Carrot
Fixed.
Fixed:Fixed: ... you guys are going the extra 1.073 kilometers to ensure customer satisfaction.
(50,000 of 75,000 shocks)
Old 04-05-2015, 10:05 PM   #98
VerusEric
VerusEric's Avatar
FMEA squad up!
Thanks for the words of encouragement. I was personally fairly upset as I'm the main person working on this project. When I put it in context though, it really didn't do that bad and would have lasted a few seasons under severe race conditions. We are dealing with a street car though and we want even more longevity built in.
I should also point out we are testing this at around 4 degrees of negative camber. This is to stress it in the absolute worst case we can.
Since we need to prove that it broke.
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
DAEMANO (04-05-2015), Jonsey (04-05-2015), MINOCIN (04-07-2015), Shankenstein (04-06-2015)
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 05:12 PM
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 574 09-15-2019 11:10 AM
FT-86 SpeedFactory Turbo Kit - Development and Testing FT-86 SpeedFactory Forced Induction 271 09-20-2017 12:07 AM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 02:41 AM
