#85 | |
not playing cards
For the sake of simplifying the model, let's assume identical corner weights so in both cases center of mass is right smack in the middle. Case 1 - mass is also concentrated near center mass. (a low polar inertial moment) Case 2 - mass is distributed out near the wheels. In Case 1 less force is required to accelerate the system about that center of mass. The opposite is also true. Less force is required to stop a rotation. If one wishes to lessen the tendency of a vehicle to spin, decrease the polar inertial moment. This argument is "kinda sorta" similar to the argument that decreasing unsprung mass improves suspension responsiveness and overall stability. Ok, have at me. Pile on.
#86 | |
#87 |
I wanna see one of the triplets with snow chains
#88 |
Me too! Those big cleated ones we used to put on our trucks in the army.
#89 |
not playing cards
no way, man. fuck up my plasti-dip. yo trippin.
#90 | |
not playing cards
#91 |
MUCH BETTER!
Though we lost you for a minute there. Have to do my science shit all day so like to get away some times!
#92 | |
Drives: 2015 FR-S
All I can do is quote a few of the many experts on this. From a pistonheads.com moderator: "Mid-engined cars tend to have a lower moment of inertia. This means they have more tendency to rotate... whether you want them to or not. It makes them quicker to turn when you want them to, but also quicker to rotate when you don't, making them harder to hold at a given angle past the limits of grip." From Car & Driver in a comparison of the Cayman and the 911 on the skidpad. The cars were set up to achieve essentially equal staedy state handling, i.e. "[t]he 911 GT3’s 1.01-g roadholding topped that of the Cayman R by a slim 0.01-g margin. Both demonstrated minimal understeer. Under steady throttle, the Cayman finally spun at 75 mph. Backtracking a bit, we found that it became nervous at 65 mph with a tendency to drift sideways when full throttle was applied at that speed. When the throttle was abruptly lifted following 90 degrees of steering at 65 mph, the response was a gentle spin. The 911 confidently stepped up the speed ladder to 80 mph before things got dicey. Adding throttle at that speed was no problem. But dropping the throttle at 80 mph made this car extremely loose. At an entry speed of 85 mph, the 911 spun every time. Why? Because the combination of lateral (cornering) and longitudinal (propulsion) loading and the 911’s large polar moment of inertia finally overwhelmed the rear tires." Higher PMI = higher cornering speed before spinning. Lower PMI means easier spins at lower speeds (although it also means faster response to steering input short of that point). |
#93 |
not playing cards
I was looking forward to a rational discussion based on some solid physics but I guess that's not going to happen. No worries.
#94 |
But dude he quoted the moderator from pistonheads you do not get more authoritative than that.
#95 | |
Drives: 2015 FR-S
I'm not sure I have the deep technical knowledge to discuss, let alone calculate, angular velocity and complex trajectories of skidding vehicles at the level to which you clearly wish to take this. Those quotes were simply provided as quickly accessed examples of the generally accepted truth that a low polar moment of inertia means less resistance to steering input short of the limit and less resistance to spinning when the limit is reached. No mathematical explanation is necessary - it's the common observation of many many experts (of which C&D is, I assume, an acceptable example to you). I started off trying to make the point that you should be careful when and where you put sandbags in your car when trying to improve winter driving, because they could materially and adversely affect handling in unexpected ways. I don't think a 50 pound bag of sand is going to improve traction in a 2500+ pound car - but it could contribute to a skid if put in exactly the wrong place. There's no disrespect intended to your intellect or knowledge - I simply think you're wrong on this issue while recognizing that it could be me instead. I can live with it either way. Best regards - David Last edited by bluesman; 10-13-2014 at 11:09 AM. |
#96 | |
not playing cards
Also equally prepared for being wrong - actually looking forward to it. Means I learned something. ![]() In the big picture, I think we can all agree upon: 1. Not driving like an asshat. 2. Being very careful about any changes we make to the vehicle's configuration. 3. Once in a snowbank, transfer some sand from the bags to under the tyres.
#97 |
Troll Hunter
Drives: fr-s, tundra
this forum is pretty funny during the winter.
I mean, it's pretty funny for me - I would avoid this car at all costs if there were snow on the ground. but I live in texas
#98 | |
Drives: 2023 BRZ
Of course, when there is a lot of weight at the rear (ala Porsche), the car inherently wants to rotate once traction is lost. |
| quick question about this car in snow | andrewmay9 | CANADA | 32 | 01-03-2015 04:11 PM |
| Buying FR-S. Quick Questions. | maverpl | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 03-28-2014 11:25 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
| Few quick BeSpoke questions | NOMNOM | Electronics | Audio | NAV | Infotainment | 0 | 04-17-2013 01:39 AM |
| Few quick set up questions | Im_SPEED | Tracking / Autocross / HPDE / Drifting | 14 | 08-23-2012 03:28 PM |
